The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #241
Back onto some real steep ground today mowing with the Challenger.
This place is STEEP. Like pucker steep.
It can be hard to get the visual perspective of just how steep a slope is with pictures. I've tried several times myself and failed. But that does look steep to me. I think I would chicken out and go straight up and straight down the slopes there, even though it usually makes the passes less efficient.
   / The Life of a Custom Mowing contractor #242
Here is one of mine with a hanging chain to show true vertical:
Just to be clear, I only hung the chain there for the pictures and removed it after the pictures.
   / The Life of a Custom Mowing contractor #243
View attachment 813985View attachment 813986
Good tool/device. If mine I would also add a rod with green-yellow-red sections for the chain to slide across which would give me instant visual recognition if I should continue going forward or turn down hill and call it a day.
   / The Life of a Custom Mowing contractor #244
This is a great idea... I'm going to mount a little chain under the front of my canopy.
   / The Life of a Custom Mowing contractor #245
Wanted to step in here and say it again:
Thank you all for contributing and also uploading your cool pictures.
Reading this thread and seeing your pictures is a real treat, and we all appreciate you very much.
   / The Life of a Custom Mowing contractor #246
The big dairies (3000+ milking cows) around here are starting their 3rd cutting. Drove by a few fields yesterday that they had finished cutting (haylage) some chopper tracks and a lot of truck and dump cart tracks and ruts in nice hay fields.
The smaller beef operations are just getting started on 2nd cutting and are being a lot nicer to their fields.
It is amazing the amount of ground the big boys cover in a day.
Of course with triple headed mowing units covering 26 to 36 foot width at a pass, then the big mergers putting 12 swaths into one windrow for that big self propelled chopper to pickup it doesn't take much time to cover a good piece of ground.
They are probably also doing haylage, so they don't need anywhere near as much dry time as putting up dry hay does.
Well, I FINALLY finished 1st cutting :oops:
Only about 3 weeks later than normal.…..🤬
Strangest summer, so much rain.
Awesome, we just finished as well, a whole 18 5x4 round bales from the last pieces that were too wet to cut last time, small potatoes but the cows like it.
Aaron Z
Little different twist today. Customer with a meadow buried deep behind a nice development. Lots going on. Tree limbs trimmed, brush to cut, field to mow, inlet/outlet structure to clear.
We cut the phragmites in the basin once a year.
Believe it or not, this is pretty steep. Not too bad, but steep enough to keep you taking it nice & slow.
Makes for a great customer. Lots of different tasks and we keep expanding the scope of what we do for them.
Kicked off 2nd cutting a few days back. Weather has been great for about a week.
Here we go again!
Long way to go until completion, but have to start somewhere, right?
Listened to the Phillies/Brewers game in the cab for entertainment.
We have an intense manhunt for an escaped double murderer going on right around the hayfields I farm. Showed up today at a customers place and there was a 1/2 dozen state police vehicles. Men in tactical gear with AR-15 or M-16 frames.
Apparently I was on the local news when I showed up in my Massey Ferguson with the hay mower.
On the way I home cops had roads closed all over our little town.
People are freaking out.
   / The Life of a Custom Mowing contractor #250
It would be a shame if he ended up in the middle of one of your big square bale. Or would it….
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
8400 GALLON POLY TANK (A52708)
8400 GALLON POLY...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
(2) CUTTLER HAMMER 200 AMP DISCONNECT (A52708)
(2) CUTTLER HAMMER...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A55973)
2015 Freightliner...
