The Laws Of Nature According to TBN
   / The Laws Of Nature According to TBN
During the course of a project, no matter where you lay a tool or other object down, it will either be:
A: In the way of something else.
B: Out of reach the next time you need it.
   / The Laws Of Nature According to TBN #102
Or it will end up in that 5 gallon bucket of newly drained oil, no matter how far away that you put it.
   / The Laws Of Nature According to TBN #103
Or it will just walk off and not be seen until you don't need it anymore at which point it will be in plain sight.
   / The Laws Of Nature According to TBN #104
The odds that you forgot to take TP along with you on your tractor increase geometrically with the distance you have traveled until you need it.
What you wear undies for........................... emergency TP.:laughing:
   / The Laws Of Nature According to TBN #105
The amount of possessions will expand in direct proportion to fill the amount of space available to store them.
Case in point....
The pencil I just used to mark the board I just cut was under the remaining piece of that board when I went to grab it to mark the next cut.
When doing a task that involves hardware (screws, nuts, nails, etc.) or connectors (wire nuts, crimp splices, etc.) always have more on hand than you expect to need. You will invariably drop/lose or damage at least one.
   / The Laws Of Nature According to TBN #108
The number of flat and lock washers will never match the number of bolts when putting it back together.
   / The Laws Of Nature According to TBN #109
Whenever using an electric buffing or wire wheel just when you get the item perfect..."PING!!!"...it flies off somewhere across the shop.
   / The Laws Of Nature According to TBN #110
If you only have 4 screws that will work for the four holes, you will drop one and loose it.
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2003 Big Tex 10PI...
TANK MANIFOLD (A55745)
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
