The hidden perils of snowplowing
   / The hidden perils of snowplowing #2
Wow, now that would wake you up in a hurry.:eek:
   / The hidden perils of snowplowing #3
That's crazy! Can't imagine what the driver thought or felt as his truck sinks into that hole that isn't supposed to be there. The mind just can't compute it. Maybe it was a collapsed storm drain. Probably eroded away beneath the asphalt over several years, but normal traffic was not heavy enough to break through the bridged pavement.
Dave.
   / The hidden perils of snowplowing #4
Toronto, east end, East York specifically, has sandy soil and with the spring thaw and melts there is sometimes sub tarmac washouts causing road holes sometimes big enough to swallow cars. I am fifty four and this has happen several times, lol. This does not happen every year and gennerally not caught on camera. Pot hole season is early spring. We also have real road issues with rapid temperature changes sub zero F to thaw and back can cause havoc in our climate. Dropping in a sink hole sure would wake you up eh?
   / The hidden perils of snowplowing #5
Wow, There's a junk truck in 2 seconds........
   / The hidden perils of snowplowing #7
If you look close it does seem to be a parking garage, I would estimate between poor construction and an over weight machine they have a new hole.
   / The hidden perils of snowplowing #9
"Can you work for less"? "What could possibly go wrong"?
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
HEAVY DUTY AUGER BIT FOR POST HOLE DIGGER (A52708)
HEAVY DUTY AUGER...
2017 Ford Explorer (A56859)
2017 Ford Explorer...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
HAULING S/A TRAILER (A52708)
HAULING S/A...
2015 MACK CXU TRI-AXLE DUMP TRUCK (A58018)
2015 MACK CXU...
