The downside of heavier blades
   / The downside of heavier blades #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am not sure you you guys with normal blades fare, but I remember little dents and dings on the hub when a blade let go going the wrong way.
Well, this happened to me today. After some bending I am still able to continue mowing, but this fall the mower is getting torn down and rebuilt. Given all my abuse I have dished out on it over the past 6 years (jeez, it feels like yesterday), probably not a bad idea.
   / The downside of heavier blades #3
Laughs - I keep telling people about 4 years. I did not realize it was 6 already.
Yesterday, I replaced a broken blade bolt. The left handed drill did not work to remove the broken stud but a snap-on splined stud extractor worked real well.
Ken
   / The downside of heavier blades #6
I have been using 4 standard brush hog blades installed in a "+" pattern on my 72 inch mower for 3 or 4 years now , however before installing them I reinforced the blade carrier with 1 inch thick steel plate as I was afraid that my carrier would end up like yours. I have had to make quite a few modifications to my mower over the years. Two major problems were the wheels and the hydro-motor. I have installed laminated brush hog tail wheels on all 4 corners. The entire blade drive system has been replaced as the 7 cu in wheel motor only turned at about 300 rpm and the bearings went out from the extra weight and impacts from hitting hidden objects. I installed a 75 horsepower speed increasing gear box (1:1.47) and a 6 cu in pto motor. The blades now turn at about 800 rpm, comparable with other brush mowers. I use this mower for cutting hay and for occasional brush mowing. The performance is drastically improved over PT's design. It mows hay from 2 feet down to 3 inches with no problem and my hydro oil temps are lower during operation.
You got some pix to share? All the stuff you write is is quite intriguing.
   / The downside of heavier blades #8
Pix of mods and sketch of the under side of the blade carrier showing the 1" X 2 1/2"steel reinforcements
   / The downside of heavier blades #10
I use them as tail wheels on 3 pt bush hogs. They are not cheap! If anyone knows of an inexpensive source of them, please let me know. I am going to try some cheap wheels with tubes for the rear wheels and and tubes in my existing front wheels and see how that works.
Ken
2023 yamaha (A55758)
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 KENWORTH T660...
1998 HARLEY DAVIDSON SOFTTAIL CUSTOM (A56129)
1998 HARLEY...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
