The different type of 4WD sytems
   / The different type of 4WD sytems #11
Clint-
<font color=blue> think what he means by this is...it will "drag/skid."
Four wheel drive, on most vehicles, is not true 4wd.</font color=blue>
I certainly concur with your description of a "fully locked up" 4wd vehicle, and the technically correct description of how something in 4wd turns in to a 2wd without the use of a locker.
However, I'd go a step further and say that not most, but almost all vehicles sold on the lot today are not designed as "true" 4wd vehicles, as you put it. (I won't get in to the whole semantics stuff of are they "true" 4wd or not - I understand where you are coming from. 'Course taking it a step further, that means 2wd cars/trucks become 1wd vehicles at "loss of traction" point.)
Anyway, the only companies I know of that puts any type of locker in their "Joe Consumer" vehicles are Toyota and Jeep - Toyota with their TRD electro mechanically actuated locker (rear only) and more recently Jeep, with their ARB style air activated "Tru-Lok" on the Rubicon TJ (again, rear only.) Sure there are some limited slip diffs out there (Dodge, Ford, etc. all have them as an option), but a limited slip ain't no locker - not by a long shot - and when push comes to shove, a limited slip diff simply can't completely lock up the axle as a solid unit when all traction is lost on one side. (This isn't a bad thing, it's just the way they were designed - and, if you get down to it, when it comes to slick road travel at higher speeds, the limited slip is ***FAR*** safer than ANY locker (engaged) out there!) Again, there might be other companies out there putting in switched lockers or even automatic lockers I'm unaware of, but I'd bet that most of them are really limited slips - mainly due to the very odd handling characteristics lockers generate.
<font color=blue>Also, people who drive 4wd's in the snow often have difficulty because when the wheels start to spin the vehicle will not just have the back end come around (as in a rear wheel drive vehicle), but the whole vehicle will slide sideways.</font color=blue>
That assumes both the front and the rear have lost traction concurrently. I have been in circumstances where the rear end has "broken loose" but the front end retained traction, and, because the front axle was "pulling" (e.g. 4wd "mode"), it helped to right the vehicle before the back end came around. (Basically the same principle behind why front wheel drive cars are generally accepted as less likely to "get in to trouble" in slick situations than rear wheel drive cars - because you can “pull” the rear end “back in to compliance.”)
Can one "break" traction in both the front and the rear by over-accelerating in a "slick spot" with 4wd, thereby getting themselves in trouble? Sure. Does that mean 2wd vehicles are inherently "better/safer" in such conditions as was suggested earlier by another person? Nope.
I think the original post (by saw dust) on this thread was great - i.e. here are some descriptions of different types of 4wd systems. Helpful and informative. Unfortunately though, it seems like the subject of "benefits of 4wd or lack thereof" comes up every so often on TBN - someone throwing out some blanket statement about how 4wd is unsafe, unreliable, expensive to own/operate, poorly designed, etc. etc. etc.
If someone wants 4wd - fine. If they don't - hey, that's fine too. I've determined that folks who believe 4wd is a "bad deal" are unlikely to change their mind - for whatever reason. All I can do is point out what the manufacturers say and relate it to my own experience as someone who has owned & operated both types of vehicles, which seems to be in direct opposition to the original post I responded to. Frustrating for sure, but such is life. /w3tcompact/icons/hmm.gif
Sidebar: The whole “drag/skid” thing becomes kindof complex due to the different types of lockers out there and the conditions in play - e.g. turning while increasing throttle, turning while “coasting”, etc. It also depends on which wheel (tire) you are referring to.
For example, the Detroit locker only engages under power and will "freewheel" the side that is exceeding the speed of the engine/transmission/transfer case. In other words, it acts much like an open diff at this point and allows each wheel to pretty much “do its thing.” Under power, however, things change significantly.
Assuming the locker is now engaged (I won't go through the whole non-locked to locked transition as it is very strange experience for the uninitiated), the “drag/skid” really isn’t accurate as it is more of a “peel out” that occurs. Since the wheel on the “inside” of the turn turn (e.g. right hand side if right turn, left hand side if left turn) is turning @ the same rate as the outer wheel (e.g. locker engaged), and since it has less distance cover, it is "peeling out" or spinning faster than the ground is passing underneath that side of the vehicle. (e.g. the outside wheel will not "drag" as it would be freewheeling, and the axle would therefore not be "locked up.")
On hard pavement, it can best be described as "chirping" sound. Of course that’s just Detroits - Lots of other mfgs. out there and different designs - some of which, if they act like a spool, may indeed lead to that "drag/skid" scenario under the right conditions. I guess my point is although it is probably beyond the scope of this thread, there are a lot more variables to contemplate about how “stuff” works and the effects different products/designs would have on a particular driving scenario. As they say, “The Devil is in the details.” /w3tcompact/icons/wink.gif
Sorry,
I have not had any experience with "Grizzly Tools" just what I have read about them in some product literature I have recieved in the mail.
   / The different type of 4WD sytems #13
hwp-
<font color=blue>If I am going up a slippery hill with a fair load the locked rear differential will overpower the steer wheels and push the vehicle straight ahead with or without 4wd engaged. </font color=blue>
Well at least you can get up the hill!! /w3tcompact/icons/laugh.gif
Seriously though, if this is a problem, you could always go to an open diff and ditch the limited slip, or if you want the ability to lock up the rear end only at certain times (e.g. an open diff in the rear end and seriously, you might not make it up that hill at all), you could consider putting in something like an so that it was open up until the point you decided you wanted a "solid axle" pushing you. They aren't cheap, but something to consider. I don't think <A target="_blank" HREF=http://www.oxtrax.com/oxlockerfile/oxpages/oxindex2.html>Ox Trax has anything out yet to fit your truck - depending on your axle of course. And Eaton's Electrac, well, I yet to see one on a vehicle not in some magazine (this is a sore spot as they've been promised for years.)
Anyway, a couple of options to follow up on if this is a major problem for you.
   / The different type of 4WD sytems #14
Well, I see I kicked up a storm and there is some misunderstanding about the skid/slip thing. The type 1 locks the front and rear axles solidly together. What happens in the two differentials does not affect that fact. Both ends are trying to turn at the same speed (with the differential splitting effort between the wheels -on the same axle-. Note that there is -nothing- that is splitting effort between the two axles.
Now when going around a corner (the sharper it is, the worse it gets) the front wheels will travel at a larger radius than the rear. The front wheels therefore are covering more distance than the rear. Something has to give and the only thing that can is for a wheel to be skidding/dragging somewhere. As for use on slick/snow roads. Yes, use 4x but be aware that you have a very poor design working against you. My comment about the -worst thing- should have been more specific and aimed at the dunderheads who have no clue as 4x other than that extra control does something and I paid a whole bunch of money for it.
Harry K
2016 Cadillac CTS (A56859)
2016 Cadillac CTS...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
Hose Reel (A55787)
Hose Reel (A55787)
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
