The day from heck
/ The day from heck #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
A couple of days ago Tamara injured her back while shoveling sheep poop and hay out of their shelter. The shelter is actually a low shed attached to the back of the garage, and there is no easy way to clean it out; it's a squat, lift, twist and dump sort of thing. Ergonomic nightmare as I pointed out in my request for a more human friendly arrangement. She vetoed me and is paying the price...but I can't say "I told you so" without appearing to be unloving and uncaring. So I finally managed to convince her to see a doctor. The doctor gave her some pills and some exercises which helped, but he warned her the injury would persist for weeks and to ease back into things.
So she went in on her day off to put in a marathon shift...and came home last night in agony. The pills can't touch it, and she's essentially bedridden this morning. Strike one.
The center diff and the catalytic on the Subaru need replacing. It will probably cost us $1500. Strike two.
And this morning the shower only gurgled. I ran into the basement and discovered our cistern was nearly empty and there is no water coming into the system. Obviously frozen or broken somewhere. 2 degrees outside in a blowing wind with a couple of feet of snow on the ground. Not nice conditions to search for the problem. Strike three.
I wish I could just call it quits and take the day off...but that's where all the issues are! /forums/images/graemlins/mad.gif
Pete
/ The day from heck #2
Man, tough day Boondox! Back injuries are the worst. Best wishes to your wife for a speedy recovery!
...at least it can only get better from this point (i hope). The water sounds like the worst of it. 2 degrees out with no water makes me shudder. Thats gotta be some tough working coditions.
Good luck with everything!
Moon of Ohio
/ The day from heck #3
Boy Pete that's a tough day. Give Tamara our best and wishing her a speedy recovery! /forums/images/graemlins/grin.gif Backs are a real pain. No pun intended.
Car problems always crop up when you don't need them. It's like the manufactuer puts in a extra sensor to let the care know the worst time to break down.
Don't envy you the water problem either. If you need help call me and I'll see about changing my schedule around.
Take care
/ The day from heck #4
After many years of suffering with some back pain. I have finally gotten to a point where I don't wake up with a backache of some type. What cured it. Retirement. I was able to take the time that doctor recommended to cure the pain.
Hope Tamara gets well soon.
No water, may require you to take the day off and address the problem. /forums/images/graemlins/frown.gif
/ The day from heck #5
Sorry to hear of your day. Hopfully things will get better from here, right? Best wishes for a speedy recovery to your wife.
/ The day from heck #6
Your wife will hopefully recover with a little rest. Not to worry.
The car........painful but it beats walking right.
Now the water.....That's an issue. You think life stinks now wait a few days. How do you get water now from a well? Is there a creek nearby to get water in the house in the interm?
Best wishes
/ The day from heck #7
Those kind of days do come along all to often it seems. Hope Tamara gets better soon. Don't let her take any more chances with her back. It's probably the worst thing you can hurt and it's so easy to think it is getting better, overextend yourself and end up back at square one.
Just think of it this way ... tomorrow will be a better day.
/ The day from heck
</font><font color="blue" class="small">( Your wife will hopefully recover with a little rest. Not to worry.
Best wishes )</font>
Yeah, that's the big problem. I snowshoed up to the springhouse 1/4 mile up the hill. It had plenty of water inside which tells me the pipe is probably frozen, not ruptured. And with about 2.5 feet of snow on the ground there's plenty of insulation...so my bet is the blockage is right near the house where I plowed the snow back and removed all that wonderful insulation.
We have a small creek across the meadow, but last fall's microburst (7.5" of rain in two hours) washed away all the hose and assorted infrastructure we used for our emergency backup. So the plan now is to get a plumber over with one of those steam snake things to rid the first 50' of intake pipe of ice. If that wasn't where the blockage is plan B is to put my 300 gallon sap tank in the truck and fill it at work, then drain it into the basement cistern via a garden hose run through the basement window.
In the days BT (Before Truck) I used to do that with a pair of mud buckets and the ATV, filling the buckets by hand from an abandoned springhouse on another nearby hill. But that was a LOT of work and resulted in me resenting every single flush! /forums/images/graemlins/mad.gif
Tam is gimping around and eating chicken soup, so it's looking better. Thanks for all the get well wishes. Pete
/ The day from heck #9
How about a hot water heater hose going from the tank into the pipe. Can you run a snake into the pipe and see it you have an obstruction?
/ The day from heck
</font><font color="blue" class="small">( How about a hot water heater hose going from the tank into the pipe. Can you run a snake into the pipe and see it you have an obstruction? )</font>
Well, that was plan A. It failed because it couldn't get past the splice from last year's accident with the backhoe! So after cutting thru ten feet of ice, the snake couldn't finish the job.
So Plan B was put into action. I drove to work (which has that wonderful unlimited municipal water supply!) and filled my 300 gallon sap container with tap water. The truck is in the driveway, pointed uphill, with a hose running from the tank to the cistern. 300 gallons only gave me a quarter fill, but it's enough to get by for now if we go into conservation mode!
Pete
/ The day from heck #12
Boy, you must have a very unfriendly neighbor, or a pretty angry enemy.
/ The day from heck #13
Sorry to hear about all you guys problems! I have been in the "no water in the winter" situation before myself when my well pump died once for 5 days. Definitely a huge pita.
Jerry, that is a hugeeee loss for you I'm sure. Is that something that is covered by insurance? Does anyone have any idea who would do such a thing?
/ The day from heck #14
</font><font color="blue" class="small">( <font color="blue"> 17000 chickens </font> )</font>
Jerry,
Are you contracted with Tyson or someone to raise those chickens ?? Is there good money in your business ?? Are these layer chickens or chickens for meat ??Just curious....
/ The day from heck #16
I'd be sitting in the chicken house with my trusty Browning.
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
John Deere Z994R (A60462)
John Deere Z994R...
2015 Gehl V270 w/ Bucket (A63688)
2015 Gehl V270 w/...
