The Biggest, Heaviest Thing You Pulled
   / The Biggest, Heaviest Thing You Pulled #41
OK, my little TC24 isn't big, I think I take the prize /forums/images/graemlins/laugh.gif 2 Chevy pickups and an 8X16 shed all at the same time.... /forums/images/graemlins/smile.gif
OK, OK. So the trucks helped /forums/images/graemlins/grin.gif
Seriously, probably the heaviest thing otherwise I've hook on to was just Saturday. Couldn't get pictures because it wasn't my oooops. But if you remember this A Good and Bad way to spend your birthday you remember how wet a part of my land his, my neighbor was mowing his part of the same ditch with his 36 HP Long. I don't know if he had a 5 or 6 ft cutter on the back, but it got hung up which in turned caused his tractor to get stuck. He tried to use the loader to get out, but the only thing it did was pushed enough dirt back up under the front of the tractor to lift the front tires off of the ground. He had the rears probably 3/4 of the way buried just spinning in soup - yes they were R1s. He came to get me, I told him I would try, but not sure what I could do, knowing that his tractor probably weighs 3X what mine does. I get to where he is at. First time nothing. I'm spinning all four tires and the loader won't even curl because his tractor is so heavy. We disconnect the cutter and I reconnect the tow strap around the front of his tractor so that it pulls down on my tractor more. Nothing. We decide to back them both up and get a little bit of a run (Hey, as much of a run as you can get with tractors in the lowest gear they got /forums/images/graemlins/smile.gif) and a little jerk. He was able to back up to the cutter (still disconnected) about 8". We give it a go he went right back to the same spot he was and about the time I got the tension out of the strap and chain ( /forums/images/graemlins/blush.gif I know don't use the 2 together, but it was the only way I could reach him and both are a lot bigger and stronger than my little TC /forums/images/graemlins/blush.gif) and I was able to jerk him up about half way out of the hole he stayed there and I backed up again to get another run. Low and behold and he came up and out. Still had to give a little more assistance when his back tires hit the ruts from the front /forums/images/graemlins/laugh.gif. We then disconnected the chains and strap and put them to the back of his tractor and around the cutter so that he could drag it out. His power washer had died so he then brought the tractor up to our house so that he could get some of the mud off. Tractor sure was a lot prettier when he returned the power washer yesterday /forums/images/graemlins/cool.gif. Sorry no pics /forums/images/graemlins/frown.gif, but like I said, wasn't my ooops.
Now that's impressive!
   / The Biggest, Heaviest Thing You Pulled #43
Nah, Garry...I met a lot of girls like that in Wisconsin, I believe it has something to do with the water, there!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / The Biggest, Heaviest Thing You Pulled #44
</font><font color="blue" class="small">( I met a lot of girls like that in Wisconsin, I believe it has something to do with the water, there!! )</font>
Nah! It's got to be the cheese and the brats!! /forums/images/graemlins/cool.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
   / The Biggest, Heaviest Thing You Pulled #45
Last fall, pulled a UPS truck out of a ditch in front of my house with a BX22. Driver didn't believe it would work and had called for his own toe truck. Posted about it at the time and opefully I won't get a load of posts again this time talking about how stupid and unsafe I was for even trying it it in the first place.
   / The Biggest, Heaviest Thing You Pulled #46
Two things to say!!!! "and all those chevies were in reverse too!!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif" and ...it feels great when u pull out a man in brown doesn't it /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif nothing wrong with being a hero once in a while!!!! jist make sure u give yer cut a liddl pat on the hood as u drive away grinnin!!!!
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
just remember to always b safe /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
TODD
   / The Biggest, Heaviest Thing You Pulled #48
This was the heaviest (most ground engaging) thing that I pulled with my TC33D > and probably shouldn't have. /forums/images/graemlins/blush.gif
It was about 8' wide & I didn't pull it when the ground was wet. It was primarily used by a small dozer that did some work on my building site.
Sorry for the dark pic... /forums/images/graemlins/frown.gif
You know your pushing the limits when you turn the wheel and your rig keeps going straight or you start to slow down and speed up and the rpm's don't change. Wheels leaving the ground is another sign.
   / The Biggest, Heaviest Thing You Pulled #50
Thanx for the tips.
I used it once & then left it to the dozer. I had to stay on level gound only.
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2018 Ford F150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F150 4x4...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
Miscellaneous Metal File Cabinets (A54816)
Miscellaneous...
