The bigger they are...
/ The bigger they are... #1
alchemysa
Veteran Member
South Australia
Kubota B1550HSD
/ The bigger they are... #2
YIKES...now there right there would spoil day plus give a new meaning to pucker power.
/ The bigger they are... #3
I'll bet he's looking for another job... I wonder what was going through his head when he went over the edge??
/ The bigger they are... #4
What a drop! Impressive indeed. It's hard to believe that it didn't flip forward crushing the cabin like a bug.
/ The bigger they are... #5
I'd imagine that under the rippers there is at least a 70 to 90 ton winch so chances are good for self recovery.....His underwear are probably beyond recovery however.:D
/ The bigger they are... #6
no winch on that either pick it back up over with a crane or a better choice would be to bring another machine up from the bottom and pick the blade and front end up so it could be started the drive it straight down over
/ The bigger they are... #7
From the pictures I would guess some of the rock ledge broke away unexpectedly.
/ The bigger they are... #8
alchemysa said:
I loved reading about the big iron on the site below. But these pics are especially breathtaking...
VanNatta Bulldozers, Crawler Dozers
That is an awesome web site! I can't believe they took the time to document all their cool tools. Usually when I express interest in big iron like this, the operator doesn't think it is any big deal. These guys clearly love their tools and find them as fascinating as I do.
I love looking at this stuff too. I've seen some really old retired logging dozers and trucks close-up. Fascinating and scary at the same time. Very heavy duty but they look amazingly dangerous. Hardly any safety considerations at all. Winches, cables, and huge swinging bits of metal here and there with few protective guards. A half dozen places to stick an arm or leg - and lose it. And the seats were just flat sheets of steel plate. (BYO cushion.)
/ The bigger they are... #11
Seriously??? What kind of crane has that kind of capacity from that far back and (2), is it even possible to bring another machine up from the bottom? It looks to be almost a sheer 75 degree drop.
/ The bigger they are... #12
A lot of times what they would do is bring a large drag line and remove the bucket then sling the dozer to the hoist cable and pick it right out of there have saw it done a couple of times Another dozer the same size and a couple of hours you could be right up to it then just get the blade picked up a little and slide it down hill until you could get it up enough to start. In loose rock like that it would slid easy have done that myself a couple of times with machines that were broke down in places almost as bad
/ The bigger they are... #13
Pick it up. My brother works for a crane rental company and they have a crane that will lift 500,000 LBS. here is a picture of a off road truck the driver drove into the Detroit river. He took this picyure for me.
/ The bigger they are... #14
"I'll bet he's looking for another job... I wonder what was going through his head when he went over the edge?? '
Forget about what went through his head.
I'm sure something went through his pants though. I'm sure he saw his entire life flash before him.
/ The bigger they are... #15
Wouldn't make any difference if he had two winches on that cat. Engine would not be able to run more that a minute or two. No oil at the pump pickup. Back in the 1950s, in Kansas City, my old man had a wrecker that would have been able to recover that one.
ron
/ The bigger they are... #16
Who does he work for....Allingham?
Rouge Steel looks pretty good in that picture. The buildings across the river are actually red, not rust.....;
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2022 John Deere 5055E (A60462)
2022 John Deere...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
Kubota Snow plow with subframe
Kubota Snow plow...
John Deere 7230 (A62180)
John Deere 7230...
