The BEST HVAC system for your home, hands down
   / The BEST HVAC system for your home, hands down #21
I have a couple of questions about AC in our new house build.
One builder insisted that they only install brand C. I have had very good luck with Brand A, and I tend to be very loyal if I find something that works well. You have seen the high end unit we currently have in another thread. Is it reasonable to insist on what we want or just roll with it?
Next question... We designed our new house with a first floor mechanical room to house all other the things typically pit in an attic. The room will be accessible from the outside, so maintenance people don't need to worry about the rest of the house as much. We can also then change filters and such without climbing as we are getting older and kids are gone. The same builder was insisting they still put the equipment in the attic. Help me understand if this makes sense.
No sense. The builder is working for you. If you do not want it in the attic stand firm on your decision. I personally would not want my hvac unit in the attic. I have repaired too many drywall ceilings from stopped up hvac drain.
You're right Sig, it's not a split system but an AC with a heat pump as well, it can reach into the 30's in January.
This is the issue with HVAC terminology sometimes.
What you stated makes no sense to me.
Generally with split unitary product, you have 1 - heat pump (outdoor HP unit with indoor air handler/blower which has the coil) 2 - Gas/AC or (indoor coil/gas furnace with AC outdoor unit) 3 - Dual fuel, heat pump (outdoor unit) with gas furnace and coil (indoor unit) .
If what you have is not a split system, it's a package unit.
Package units come in
1 - Gas pack (A/C with gas heat).
2 - Heat Pump (with strip heat for back up heat).
3 - Straight AC (very odd, generally I come across them in Florida, added it's getting to the point with overall sales, it's cheaper to buy a package heat pump or gas pack than a straight AC package unit).
4 - Dual fuel package unit. Combination of heat pump with gas for heat (back up heat generally) with no heat strips.
When looking for a "coil", you either have the indoor coil (coil inside a air handler or dedicated coil on a furnace) or outdoor coil (which is the coil on the outdoor condensing unit, or with package units, you have the condensing unit coil with evaporator coil.
What's happening with SEER rating is one of the coils (or both of them) are getting larger and larger (physically) for efficiency ratings.
110% agreed.
However, if it's a two story house, there could be design issues with the way the house is designed which makes it more difficult to run ductwork from the first floor to the second floor, would be my best guess.
I have 3 systems. Two in the basement mechanical room which handle the basement and first floor, and one system in the attic, which handles the third floor sleeping area.
Generally speaking, if a system is done on the first floor to handle the second floor as well, both duct systems are run between floors, with the first floor having vents in the ceiling, and the second floor having vents in the floor.
As to my attic system, primary drain pan, secondary drain pan along with multiple safety float switches, 17 or 18 years here, never had a problem.
At the end of the day, the however the customer wants it and is willing to pay, that is the way the customer gets it. Worst case, if your a professional in any aspect of the industry and disagree with what the customer wants, you make sure you include why you disagree with the customer in what work is to be performed on the proposal.
   / The BEST HVAC system for your home, hands down #24
Sometimes it's the smaller things that don't appear very quick per system failure.
Not pulling a proper vacuum.
Not using decent solder.
Checking pressures, but never checking airflow and static pressure.
Having a long line set run but not following the manufacturers guidelines on what needs to be added.
The only reason for this post is that when you ask about a brand of equipment wondering "how good is it?", the reality is pretty much all of them will work fine when installed properly.
I went 2 stage 16 SEER variable speed because I was able to utilize a personal use program directly from the manufacture. My rep wanted me to try a "higher line" but it required a proprietary communicating thermostat. For myself, I won't touch a propriety communicating thermostat made by the manufacturer (and the only tstat you can use) due to way to many potential issues down the road.
My dad's buddy has a home about 40 minutes from us. He lives in Pa though. He called me, dealer installed a Lennox high end XP system with proprietary thermostat. He called me because the installing dealer wanted $1,600 to replace a thermostat that was out of warranty by a year. I was able to get the job done for him for $900, and that was only because the thermostat was well over half that price.
2 Stage, variable speed air handler / gas furnace with any Honeywell thermostat is my high end limit LOL
Yep… married at the hip until divorce….
Some of my locations don’t have Internet so that would be a problem
   / The BEST HVAC system for your home, hands down #25
I custom fabricated a large catch pan with two drains going to daylight over the kitchen sink window and once my sister in law called to say water dripping...
A well designed catch is money well spent.
As to sizing this 1950 home without A/C or central heat I downsized...
Reason is wanting to keep the circuit at the 30 amps that was available from the old dryer circuit when dryer went electric.
Twenty years now and even when 110 outside it remains nice inside...
When two bedrooms added 10 years ago did not upside and still good.
Pulled all sheetrock to insulate plus attic and premium windows and large shade tree blocks much of summer intense heat.
Brother's friend HVAC company owner followed the job and said seeing is believing... but as a contractor he needs to be certain his systems have enough capacity and therefore specified larger...
I got stuck on a HVAC/Internet problem more than a couple of times. End of the day, the problem was with the internet and had nothing to do with the HVAC system.
It's great if you live in a city area with great internet connection, but overall due to the area where I live and where a lot of customers live, the internet is something I'm not a proponent of to play with your HVAC system. Install it, let her run, install secondary safety devices if need be, but don't worry about it (I understand the same may not be said of commercial applications such as hospitals).
That said, no qualms with putting a electronic water safety device to alert you via the internet to let you know with potential water issues that could cause damage in a residential application.
   / The BEST HVAC system for your home, hands down #27
Installation is super important, but I can tell you after 20+ years experience in hvac and many additional years in aviation electronics that brand in hvac systems matters.
In florida systems go through the harshest trials, and ICP products are the best.
The worst in no uncertain order: Trane, York, Lennox, ruud/Rheem, etc. Most are called the worst because of evaporator coil failure rate.
I actively work in the field and have since 2001, right now we’re replacing 10-13 year old Goodman’s that we installed. Goodman is my second favorite brand (a distant second) . At 13 years, in our climate, they are generally falling apart.
That's exactly why I went with a 2 stage compressor on this new install.
I'm curious about the humidity and how a 2 stage compressor with a variable speed indoor unit will handle it vs a 13 SEER variable speed single stage compressor.
Seeing is believing. Currently, after seeing the whole house dehumidifier, I'm a believer. The question becomes if I still need it with 2 stage variable speed.
FYI, ICP and Carrier are pretty much the same. My ICP rep has a Carrier signature line, go figure LOL
I've got to ask, in all your 20 years plus, how many heat pumps and gas furnaces have you installed since you mentioned Florida?
EVERYONE has had evaporator coil leak issues to the point that every manufacturer has had a class action lawsuit settled out of court.
EVERY company you've listed I've been to their manufacturing facility. I'm come to the conclusion same crap, different day.
I'm not trying to be combative, just after dealing with all these manufacturers, every one is screwed up somehow, somewhere if you deal with them long enough to see it. Don't even get me going where ICP is screwed up, but overall, I will agree with you that overall, the quality even with pretty much nothing being made in the US is pretty good.
Average life expectancy of a new HVAC system is 7-13 years. Blame that on the government IMO for having all manufacturers trying to meet energy standards which always change over time.
Next year, it's A 15 SEER MINIMUM, 2025, say goodby to R410A.
   / The BEST HVAC system for your home, hands down #30
I don't remember the unit you speak of, but are you dealing with the builder or the HVAC contractor?
I would also think that although you had good luck with Brand A, you probably had better luck with the installing contractor installing brand A.
Personally, I could never understand why people build homes but never have the choice of what HVAC system they want, let alone being stuck with a crappy $50 thermostat in a 500k home.
I have a high-end Trane.
I am dealing with the builder. We have 2 builders bidding. He wants to use Carrier and says that is what everyone in the area uses. I hear what you are saying about the contactor, but how do I know if they are good or bad until it is too late?
I really like the continuously variable fan. We have save literally hundreds per month in the summer and still lowered the temps.
2009 TRANSCRAFT STEP DECK TRAILER (A45333)
2009 TRANSCRAFT...
2013 Komatsu D39EX-23 Dozer (A42203)
2013 Komatsu...
2016 Ford Explorer SUV (A42744)
2016 Ford Explorer...
2018 Kubota L4060 Tractor (A44391)
2018 Kubota L4060...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A43004)
2016 FREIGHTLINER...
SET OF (4) USES LOADER TIRES (A45046)
SET OF (4) USES...
