The Angry Beaver
/ The Angry Beaver #1
WranglerSS
Ball Ground, GA
Kubota L3240
Here is my 3 point stump grinder I just built. I bought the gearbox, hydraulic rams and PTO shaft from Woods. The rest I made using my 2x4 Torchmate Plasma table, Bridgeport Mill, Sheldon Lathe and lots of welding wire.
I'll be glad to answer any and all questions instead of trying to list every detail in the initial post.
/ The Angry Beaver #2
Well, get ready for the questions. First I want to say, "Awesome". More pictures please.
What did you use for a gear box? Is it one to one ratio? How about the wheel? make your own or buy it? If you made it I would be very interested in some picture and explanation as to the wheel and gear box hook up?
How much where the teeth and where did you get them?
/ The Angry Beaver #3
Holy.. ! Nice work man!
Though, when I first saw your title, I thought of something else :)
/ The Angry Beaver #4
That is one fine piece of work. Hows chances of a working video and some more close up pics, what size tractor....Mike
/ The Angry Beaver #5
That's awesome man!! I am also interested in the wheel/gearbox setup.. This stuff really enthuses me. How long did this project take you?
/ The Angry Beaver #6
Very nice work.
/ The Angry Beaver
Thanks for the replies.
The gearbox is a Woods with 1:1.92 ratio which basically doubles the RPM from the PTO. I run it at 2000 tractor RPMs which seems to run pretty smooth at the grinder.
The wheel I did myself. I bought a piece of 3/4" thick by 21" diameter plate and bored a hole in the center to accept a 12 spline hub to match the shaft on the gearbox. Here are some pictures of the wheel on the Bridgeport as I was trueing and drilling the holes for the teeth holders.
The teeth are from a company called Greenteeth. I chose them cause they are indexed so you can get three cutting sides per sharpening. I think I paid $375 for the teeth and holders. I ordered them from Lewandowski Equipment Company.
/ The Angry Beaver
Here are a couple of videos from yesterday on its maiden grinding. The tractor is a Kubota L3240.
/ The Angry Beaver
I haven't calculated the hours it took me but I would guess at least 40.
/ The Angry Beaver #12
I don't think that I need one but I want one.:drool:
That is a good build.:thumbsup:
/ The Angry Beaver #13
you need to shorten and get stouter/larger arm to stop the bounce or it is going to break, the teeth are the best that is what I used on my vermeer they seemed to last for a long time, also dry not to dig dirt, I used to take a shovel or grub hoe and move the dirt/rock away from the stump reslly helps with the saving the teeth
/ The Angry Beaver
I think it was taking too big of a cut and moving too fast in the video of the maiden grind. I've now done 8 stumps and gotten better at feed and speed.
BTW hickory stumps are hard as all get out.
/ The Angry Beaver #15
Nice work. I need one also and not through with my research on build plan. The title is a bit leading but glad I read it. From the video it looks like saw stability might be looked at closer. Details on the wheel construction is what I need most. Thanks for the info.
/ The Angry Beaver #17
Very nice build. I do agree with Jarokoro that your swing beam assembly looks like it needs more torsional rigidity. It's hard to tell if the flex is in the tube itself or in the u-joint where it attaches to the frame.
/ The Angry Beaver
It isn't flex. What is happening is if I take too deep of a cut or go to fast the cutting wheel will climb instead of cutting. I've done 8 stumps now and have figured out how to run it effectively. Works as designed.
/ The Angry Beaver #19
Nice build. I need to make me one of these too. I've got some stumps to grind out myself.
Chad
/ The Angry Beaver #20
Nice work. Question is the rotary table on the Bridgeport a Pratt & Whitney? I have a 12" rotory table that's P & W but cannot find any manual or how to use it.
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
