Front-End Loader The advantage/disadvantage of a canopy on a loader tractor
   / The advantage/disadvantage of a canopy on a loader tractor #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
A pair of oak planks bolted to the bottom of my 5′ loader bucket makes it into a very usable fork lift for small jobs. Today I moved 13 pieces of scaffold to re-pile it by the simple expedient of sticking the forks through the bunch of leaning scaffold and lifting it to a new location. Once clear of the grass I had realized that the two pieces with wheels attached which I needed were not in that pile, so I put the 754 pounds of iron back down and located the errant pieces leaning against an old trailer.
So then I skewered the much lighter pile of scaffold ends and loaded on ties and aluminum planks. My 35 hp tractor easily carried the load up a slope to my latest construction project, a large deck elevated about 7′ above the ground. I wasn't sure that the TAFE 35DI had enough lift to put the dangling scaffold onto the surface of the deck, but a little tilt of the bucked enabled the whole affair to clear the lip as I eased up the slope. That part worked. What went less well was the way the top plank tipped over the the top of the bucket and crashed down onto the canopy above my head, then dropped to the ground with more damage to the plank than to the canopy.
So a protective canopy is good for more than shielding the tractor's operator from solar radiation: it's a hard hat attached to the tractor. Unfortunately, like a hard hat, it restricts visibility. Without the canopy I'm pretty sure I would have seen the plank in an awkward position and adjusted the bucket, but weighing the plus and the minus, I'm glad I paid the $700 for that ugly piece of plastic above the driver's seat.
Back when I used this loader to move materials for two garages we built, I had clamps firmly attached to the upper edge of the bucket against this precise hazard. I'll put them back on before I lift anything else with potential to slide over the top. Lesson relearned.
   / The advantage/disadvantage of a canopy on a loader tractor #2
The best mishaps are the ones that you live to tell about.
I'm happy to hear that you weren't injured.
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
Utility Trailer (A50515)
Utility Trailer...
Chariot 12' Inclosed Trailer (A50515)
Chariot 12'...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
