Thatcher blades for 300 series?
   / Thatcher blades for 300 series? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I bought a X300R last year and have about 15 hours on it now (1 oil change). The tractor has been a pleasure to mow with (except the time I tried to mow 5-6 hours after a morning rain shower..:()
However, now that the snow has finally melted and the ground is nearly dry enough to drive on - I'd like to remove last year's old grass.
Any recommendations on a thatching blade - manufacturer (OEM), etc.? Or other suggestions?
Thanks for any insight.
AKfish
   / Thatcher blades for 300 series? #2
AKfish
They make dethatcher blades, coil spring on the ends, but you will have to search for the length, and hole size. They also make dethatcher rakes that you push of tow. Spring loaded.
   / Thatcher blades for 300 series? #3
I use an inexpensive Sears tow behind dethatcher on my 3 acre yard, and it works well to pull up the dead growth. I also have a fan enhanced materials collection system, so I drive around after dethatching, and just pick up all the loose material with that. Sure beats raking! If I had a JD, I might look into the front mounted dethatcher they sell for them. More pricy, but it looks like it would work well, and would save one pass around the yard.
Appreciate the suggestions. Might check out the JD thatcher. Haven't spent any time on the residential page of the JD web site.
AKfish
2014 CHEVROLET IMPALA 4DOOR SEDAN (A56138)
2014 CHEVROLET...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
Rotadairon RD100 III Rotary Soil Tiller Tractor Attachment (A55851)
Rotadairon RD100...
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2016 HAULMARK 24 ENCLOSED TRAILER (A55745)
2016 HAULMARK 24...
