Thatch-mow-clean it up in one pass
   / Thatch-mow-clean it up in one pass #1
jmarotz
Nampa, Idaho
BX 24
Studied a lot of thatchers and most either trailed behind or went on the 3 point but you still had to go back and clean up the thatch.
Guess I am kind of lazy, seemed like to many steps.
Works like a dream.
   / Thatch-mow-clean it up in one pass #2
I like your idea! I don't think you are lazy- its a great time saving device. It looks very well made, I see you had to remove the brush gaurd and I assume you are using your FEL controls ?
   / Thatch-mow-clean it up in one pass #3
I made one very similar to yours about 1 1/2 years ago, it was a winter project. Mine is more manual then yours but I also had to make a hitch for the front of the Honda tractor too so I could use it in the same manner. This design works very good, the ONLY draw back I can see, and I see it on your tractor too is the dust it makes! I tend to scratch my grass at the end of the year a couple times then clean the air cleaner, mower, and then finally change the oil. Dust is a real killer.....
Great minds think alike!
Craig
Harley,
We must think along the same lines I checked out your thatcher and see you did the same thing I did with my ag-fab core areator with the exception that I have 2 tractors weights I put on mine for a total if 300 lbs.
Yes I do have a float position on my rear remotes.
Shmudda,
looks great, I'll bet you love getting it all done in one pass.
   / Thatch-mow-clean it up in one pass #6
jmarotz, I want to put side plates on my areator so I can support the axle on the ends. I have some solid and open core cement blocks I use for weight on the areator, it really depends how hard the ground is here for the amount of weight I have to use. Nice work on your builds.
Scott
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
STORAGE FEES (A58018)
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
207010 (A55853)
207010 (A55853)
