that time of year again...time to put up some wood
   / that time of year again...time to put up some wood #21
I obtained 4 sections of pallet racking from work and built 4 wood sheds out of them. I cut the uprights with one leg about a foot shorter than the other. Used 4 horizontal beams 2 on the bottom, 2 on the top and framed up a roof with scrap 2x4 and 2x6 lumber with 2 sheets of 10' pole barn steel for a roof. 2-48" x 48" pallets on the bottom for the wood to sit on and some fence wire inside the uprights to contain the wood and each one will hold over 1.5 cords.
I no longer cut wood when there are leaves on the trees unless it's storm cleanup. Fall and early spring is the time to do it. I am also learning how to kill and cut the undesireable species to prevent resprouting using the hack and squirt method. Another tactic I employ is to cut the stump as low as possible and stack the brush on top of it for burning in the fall or spring.
   / that time of year again...time to put up some wood #22
I recently found some used cages from ICB totes that I started using for wood. They really work well and cut down on handling the wood. I toss in as I split, don't have to pickup again, and no more pallets of wood falling over when I move them.
   / that time of year again...time to put up some wood #23
Those containers and metal pallets are still pricey here.
Would love to get a deal... the less times you need to handle something the better... good job!
How much of a Cord do you figure each holds?
   / that time of year again...time to put up some wood #24
I would guess they hold about 1/3 cord. My tractor will pick up about a 1,500lb pallet and it is about at its max if I stack a few rows above the top of the cage (Osage orange and honey locust). I picked up 30 of them from a recycling plant. They were selling the ones with cages only, no plastic tote for $18 each.
   / that time of year again...time to put up some wood #25
Thats an incredible price and a nice find...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
43029 (A51691)
43029 (A51691)
