That T&T PO Check Valve Urban Legend...
   / That T&T PO Check Valve Urban Legend... #11
Henro,
If a valve works perfectly when on a new tractor it might not later on in the life of the tractor. There are many reasons why this may be happening. The #1 problem with tractor hydraulic systems is the lack of proper maintenance. Change all the filters hydraulic filters religiously. Most systems have 2 or three filters. Usually one of the filters requires some mechanical ability to change. If you change just one filter of the 2 filters then just doing this will catch up with you during the life of your tractor. If you have a dirty hyd. system then the dirt is cutting into the valve seats and o-rings and causing a drift or by-pass. Tractors that have wet brakes can cause metal particles to get into the system if brakes are worn out and are not replaced in a timely manner. The older a tractor gets the likely hood that the hydraulic valves drift will increase. Most tractors use a transmission/hydraulic oil from one oil sump to lubricate the transmission, run the power steering, power the braking, run the PTO & supply flow to the exterior attachments. Use the factory recommended oil & change the filters and you still will have some drift with time.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
2019 Ford F150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F150 4x4...
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
