Thanx Soundguy,Slowrev,Hambone, and Art
   / Thanx Soundguy,Slowrev,Hambone, and Art #1
BRUSHTAMERS
N.W. Oregon
Montana 5740 C
Took some advice from from you guys, and went to the horses mouth,as it were. I gotta tell ya, from the time I ordered this unit(servis/rhino 1348 boom flail), till delivery, was in excess of 9 months. Repeated calls to the parent Co. by myself and dealer met with nothing but stalls, the units are built in the U.K., and aren't shipped over until they have a container full of those particular models. Unfortunatly was ordered/shipped sometime after 9/11, which was brought up as an excuse ad naseum. Had some trepidation about talking to these guys after all those stalls, but had great luck with service folks on direct question about the "correct oil" Apparantly the Brits use 10-30 wt. instead of tractor hyd. fluid in the main tanks of these units. Was told that grade oil would work, but if I were to change it completely, that tractor hyd. fluid would be their choice for pump and hyd. motor longetivity. Sooo guess I'll drop the drain plug, crack a whole bunch of fittings open top and bottom, and try to drain 40 gallons of oil that I don't want in my hyd. system out. Got quite an oil burning 292 Chev in a 1978 1 Ton, wonder if I could get rid of it that way. Thanx Guys,Dan'l the brushtamer
   / Thanx Soundguy,Slowrev,Hambone, and Art #2
Glad you found out what kind of oil you needed in the beast.
   / Thanx Soundguy,Slowrev,Hambone, and Art #3
Good luck!.. Guess they have a cheap supply of the 10wxx stuff.. so that is what they send to you with.... making you pay the higher bill later. Lets see.. 40 gal.. thats about 250$ worth of oil if you buy in the 5 gallon pails. You might be able to buy a 55 gallon drum of tractor fluid from a distribuitor for that price... then have 15 gal left over.. etc.
Soundguy
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
1065 (A53342)
1065 (A53342)
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
