Thank You Tractorbynet: BX24 Seat and Axle Lube
   / Thank You Tractorbynet: BX24 Seat and Axle Lube #1
dougtrr2
Platinum Member
SW Iowa
BX24
I mainly lurk here as I have little to add to the expertise. But I had to say thanks to all for two things.
First was when I ran across the thread about low fluid levels in the front axles of BX24's. I went out and sure enough mine was low. Not a lot of hours so I don't think any damage was done.
Second were the threads on the upgraded seats for BX24's. I was at my dealer last night to get a new tail light lens (don't ask) and I asked about the seats. The parts man went and talked to one of the owners and next thing I knew I was walking out with a new seat for free. My tractor is over two years old.
If it weren't for this site I wouldn't have known about either issue. Now if I can just figure out how to keep the shroud below the steering wheel on. Mine just doesn't seem to fit right. I ordered a new one last night as the fingers are breaking on the old one.
Thanks again
Take Care
Doug in SW Iowa
   / Thank You Tractorbynet: BX24 Seat and Axle Lube #2
Thanks again
Take Care
Doug in SW Iowa
The new one should fit much better! The part was revised about a year ago.
   / Thank You Tractorbynet: BX24 Seat and Axle Lube #3
I glad you got a new seat, But:
You needed to read on TBN to check the fluids in your machine? Let me give you a hint then-go check your car's oil also;)
   / Thank You Tractorbynet: BX24 Seat and Axle Lube #4
Easy to overlook axle grease, but a reminder to check 'em all..
Welcome to the site!
   / Thank You Tractorbynet: BX24 Seat and Axle Lube #5
OUCH !
What? Where do you check oil in a car? (I did see the smiley face)
But, I would ask how many people check the fluid level in a manual transmission on a brand new car. There are some levels you would normally expect to be done by the factory or dealer. It is a good wake up call to not take things for granted. It is great use the collective wisdom here and try not to duplicate other lessons learned.
Take Care
Doug in SW IA
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
12ft Freedom Chip Body (A51573)
12ft Freedom Chip...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
