thank you,my new bx1850 has finally arrived!
   / thank you,my new bx1850 has finally arrived! #1
shrekbelly
at long last, my baby bx was delivered last night . . . with la203 fel,weight box, grill guard, 54" fine cut deck, and hd 60" front blade with cutting edge and squeegee edge.
i was put through the delivery info on the tractor and had enough time to get it under tarps (it may not fit in my 12' x12' lawn building. before lots of rain came.
it will be silently acclaimed as king of our hilll (road), as my neighbor has a new deere la150 and our other neighbor has an '89 deere 425aws.
i hope to get it working next week, and i expect to have some fits removing the fel etc. . . . the dealer made it look somewhat easy . . .
i just wanted to say thank you to all that gave me insight and info towards my buying decision.
home at last. thanks a million ---once again. robert a. ////a.k.a shrekbelly
   / thank you,my new bx1850 has finally arrived! #2
Congrats on your new purchase..... they are a pile of fun, and practicality!
   / thank you,my new bx1850 has finally arrived! #3
Congrats on the new purchase. I do not think you have any problems. My FEL was a challenge. I added a little bit of machine grease to the pins and joints and have had no trouble. Also it gets easier as the paint wears off.
   / thank you,my new bx1850 has finally arrived! #4
Congratulations. Mine was delivered yesterday and it joins a BX24 stablemate. Let me know how shifting between front, front and mid, and mid only PTO is. Mine is pretty stiff! I did not get the FEL as it was bought to be a mower companion to the BK24 TLB. Check the fluids. The coolant was very low on mine when delivered. I show .6 hours after mowing today! It came with .3 hours on it. How many hours were showing on yours? Curuious.
   / thank you,my new bx1850 has finally arrived! #5
congrats on your new machine.
you'll get used to dropping and installing the loader. takes me about 2 mins each way now.
   / thank you,my new bx1850 has finally arrived! #6
You'll find the loader is really easy to R&R as long as you do it on a flat spot. If you drop it on an uneven surface it can be a real hassle.
The MMM is the real grabber. I've done it probably 15 times and it's still a pain! Surely someone at Kubota can devise a better mower mount! When you put the deck on make sure you get the driveshaft securely fastened. Grab it and shake, pull, whatever. There are some horror stories about the damage if it comes loose.
   / thank you,my new bx1850 has finally arrived! #7
Yes, removing one from my BX24 caused me to buy the BX1850 for mowing on which I could keep the MMM on, without removing it very often. Have to say though that mowing without a FEL and B/H attached is so much easier! With weekly mowing, removing and replacing the B/H and FEL from the BX24 for mowing was just not reasonable.
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2019 JOHN DEERE 5090M LOT NUMBER 92 (A53084)
2019 JOHN DEERE...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
