Texas Fall/Winter thread!
/ Texas Fall/Winter thread!
Jim,Brandi?? OK, fixing to "try" to get on those trees I need to remove, the rental place now has a Komatsu PC35 MR2 excavator. I'm thinking it would be faster than a Backhoe, should be strong enough (better than the Terramite) and is the same $$..(looks "funner" too:thumbsup:)
OH, has an 11' depth which is 8' more than I need:laughing:, they also have a mini with 7' dig depth, but didn't ask about that little thing.
Heres the web sight, scroll down and you can see what they have.
http://cobbrentalandequipment.com/heavy_equipment
/ Texas Fall/Winter thread! #1,622
Jim, I tried to find if you had a garden thread somewhere? anyway, has your fence been keeping the deer out good and how high is it? I'm betting I will have to raise mine since the deer like coming in the yard. They have become somewhat dependent:laughing: Hey! guess that makes me a 1%er at least on my place:D
Dennis, our deer come right into our yard too, but they do not challenge the 7' net fence. Just use some 8' t-posts about 15'-20' apart and string that deer netting between them. It's the easiest fence to put up and take down as needed. I use twist-ties and take the fence down in the spring to plow and lay out my garden. I'm buying onion sets this weekend. I tilled my garden up really good in the fall and it is still nice and fluffy, but the recent rains really soaked in and it is wet.
Jim, thanks! I knew yours was at least 6', I already have some 8' T post. Was thinking the deer would be jumping a 6' though, they clear my 4' with room to spare. I also have some field fence so I was going to us that..maybe..
Oh Thoughts on my above question on the excavator (size wise) since I know you have experience with one. thanks
/ Texas Fall/Winter thread! #1,624
Jim,
The deer netting is great. :thumbsup:
I took ours down last fall and left the T-posts in place. I plowed the garden in the fall with my old double moldboard plow so water could
help bust up the deep clay by freezing and thawing this winter. And that did start the rain 2 days after I plowed after not having any rain since last May. We already have our years worth of snow for 2013 and the pond is brim full.
I used a piece of plastic pipe on one end as a gate attached to a T-post corner pole with a couple strips of Velcro around it for a gate latch. I used old plastic baler twine that we save off the hay rolls for tying on the netting to the posts. It was great to just wind the fence up around the pipe and carry it to the barn under one arm.
Thanks again for a great idea.
Ron
/ Texas Fall/Winter thread! #1,625
Cobb Rental & Equipment - Rental Equipment
Dennis,
Get the bigger of the two excavators. It is just the right size for stumps. The other is more for trenching and such. Let us know how you like the Komatsu.
hugs, Brandi
Dennis,
hugs, Brandi
Thanks Brandi! I wasnt sure if that was big enough, I left the trees standing as you guys recommended too:thumbsup: I know the backhoe they have would do it, but not having to drop the pads for every stump seems like it would go faster.
/ Texas Fall/Winter thread! #1,627
Yep, it was damp yesterday morning, but then sunny and very nice yesterday afternoon. Then sunny and cold this morning.
And of course timing is the most important factor in whether or not a rain dance succeeds.;)
You are right, Bird, as in much of life......."Timing is everything".
Charlie
/ Texas Fall/Winter thread! #1,628
Dennis,
hugs, Brandi
I've rented the mini-ex and find it great for getting into tight spots and going through narrow gates, but the PC35 would be my choice for any 'real' work. Even if you won't be digging deep, you'll find the extra reach of the longer boom is terrific. Just like extenda-hoes on TLBs, you just never seem to get enough boom length and reach. It costs more, but you'll get so much more work done with the bigger machine that you'll find it cost-effective.
/ Texas Fall/Winter thread! #1,629
As slow as an excavator moves...........it can work circles around a backhoe. Your in for some fun.
hugs, Brandi
Well shoot (cuss), I rented the excavator, got home all excited. Then it turns into "gold Rush look-a-like". Little thing digs....slow, not what I was expecting, but it digs.
About 2 hrs into "the dig" one of the rubber tracks came off the rear drive wheel?, OK called the after hours #, by the time they called back I had it on (PITA) Actually it jumped itself back on:D 2 more hours and I'm getting the hang of this little thing, then a hydraulic line gets a pin hole where it flexes, looks like a whale blowing every time the bucket is actuated, so I shut her down:mur: So now it sits while I wait for a call...
My tractor lines are to small or I'd hijack one of them. I must have special Oak trees:laughing:!! it takes nearly 3-4' all the way around to be able to push them over. I'm dam sure glad you guys told me not to cut them down, the one stump I cut 5 years ago was the hardest so far, cut off at the ground.
I know I dont like rubber tracks now, but I like the joysticks (thumb drive) It is a blast, but next time I'm getting a bigger machine, or dynamite!!
Dont know how they will deal with the hose, but I hope they do house calls:laughing: And no, I didn't hit anything:thumbsup: 7 trees to go
One of the "holes", ever see that movie with Siqourney Weaver:laughing:
/ Texas Fall/Winter thread! #1,633
It has been my luck (so far) to tie a chain up high on the tree. As high as somebody in the FEL (carefully) can reach. Then hook it up to our 5420 and pull it over. The first big post oak we actually chain sawed it to a notched hinge but when we pulled, the whole thing pulled over, trunk and all. So now while the ground is damp, I just pull the whole thing down with the tractor. No need to hire a stump digger. :)
Dirt was soft down to around 16" then the red clay was like bedrock. 3" dig on each pass:mad: I think I need more weight when the ground is this hard at depth. It will get it done though.
I thought about chianing up high on the tree, but I doubt it would have worked on these trees, but who knows, this was somewhat "safer".
/ Texas Fall/Winter thread! #1,635
Dennis,
Sounds like it is a little on the wore out side. How wide a bucket is it?
Track tension is supplied with a grease gun. There should be a side plate on the track roller assembly that is taken off to get to the grease zerk. A few good pumps of the grease gun should supply enough pressure to keep the track on. Do you have a TSC nearby for a temp line? If so........take it out of the rental fee.
hugs, Brandi
Brandi, I was just thinking about TSC:laughing:How funny..
Bucket looks to be about 20" and has good teeth.
They called yesterday,(had the girl do it) said they couldn't get the hose in until Tuesday?? Also said if I operate it, I m responsible for any damage and to bring it back Monday morning. I figure I have 3-4 hours left on it and will have wasted 2 hours in hauling time.
It's the hose for the bucket (curl), so any easy swap, may have to run up to TSC, Line would be cheaper than 2 more trips in Diesel to the rental yard.
Wish I could have got a 400!!!:D That would do it and then some, for about $1500 a week:shocked:
/ Texas Fall/Winter thread! #1,637
Dang Dennis! Your trees seem to be winning this battle. It's bad enough to rent equipment, but when it's so much trouble to keep going, the frustration level drives me nuts.
The hoses on the excavator are probably ORFS (O-Ring Face Seal) types. That pretty much eliminates TSC hoses. My New Holland TLB uses ORFS and I love them except when I'm payin' for them. Your leak is typical of an aging hose. I don't know about the track jumping off except Brandi's explanation of tensioning with grease is common. You have to ask yourself if Cobb Rental is doing maintenance, inspection, and repairs on their equipment. A one-time renter like yourself should not have to deal with those kinds of issues. I think I'd ask for a full days rental refund and maybe hope they would give you at least a half-day credit.
Of course, if I weren't completely on the other end of the county, I could get those trees down for you in a hurry. Weight is your friend when working to fell trees. I'm not sure what the excavator weighs, but my TLB is 20k lb +.
Jim, I wish you where closer, shoot I'd buy you a brisket, some Blue Bell and take your grandson fish'n:laughing:
I read the contract (yeah finally, of course it's say's I'm responsible for every thing excluding the war in Iraq) m I thought it would be at least a 35HP, but it is a 29hp, less then my tractor:thumbdown: Weight on the paper work says 8,245#. I will call TSC, if they possible have something I will go look at it, but I will try to contact the owner before I use it (just in case), he didn't return my 2nd call yesterday, but had the front office girl call:confused3:
The learning curve wasn't nothing, actually a fun machine, but I cant think of what it would be good for on a job site that something else would be better suited.
I may pull the hose and see if it has a seal also, on the outside it looks like a compression fitting same as my Kioti. Also noticed this hose is not original. It is a small pin hole, was hard to locate, but when actuating the curl, it sprays a mist of maybe half a "T" spoon of Hyd. fluid. I even thought about a hose clamp, but....
Thats the truth, feel like I'm qualified to be on Gold rush now
I'll try, but them having the girl call and warn me I'm responsible...hmmm I get a feeling I know where this is going.
I think your 1000% right, I figured that when I finished the 1st stump, if it didn't have the teeth, I'd been really screwed.
Here is the "pin hole" (at the tip of my finger, notice it blew out. not crushed are damaged by me.
Here is the fitting, looks like a standard compression fitting. Edit, noticed after posting that I didnt get the end in the photo,eeerg!
