Testing Temp Sensor?
/ Testing Temp Sensor? #1
Eric_Whitney
Columbus Ohio
Ford 1210
Could anyone tell me how to test a temperature sensor? I have a Ford 1210 that has Oil, Temp, and Battery lights. When I turn the key right before starting the Oil and Battery light stay illuminated until the motor starts. The Temp light never comes on, but I don’t know if it really should? I checked the Temp Bulb and it and the socket are good. Any idea how to test the sensor, I want to make sure I know if the tractor is overheating. Thanks
Eric
/ Testing Temp Sensor? #2
</font><font color="blue" class="small">( Could anyone tell me how to test a temperature sensor?)</font>
It depends whether it is a switch or resistive, but the
process is the same assuming you can remove the sensor.
Place an ohm meter across the sensor and put it in a
container of cold water along with a known accurate
thermometer. Heat the water gradually and note the
resistance vs. water temperature or where the switch
actuates. You can compare this to the manufacturer
specification for the sensor.
/ Testing Temp Sensor? #3
Eric,
To test the light and the wiring from the sensor to the light, remove the lead that is connected to the sensor. With the tractor running, ground this lead, either by directly touching it to a good ground, or by attaching a jumper to ground. If the light comes on, then you know that the circuit from the sensor to the light is good. If it does not come on, its time to start tracing the wire to find a bad connection, or break in the wire some where.
This also works for guages to tell whether the guage, wiring, or the sensor is bad.
Good luck,
DT
Thanks Rick,
That makes me feel better knowing it should not light at start up.
/ Testing Temp Sensor? #6
I have never been able to find manufacturer's specs for temperature sensors. Do you have a good source?
/ Testing Temp Sensor? #7
</font><font color="blue" class="small">( I have never been able to find manufacturer's specs for temperature sensors. Do you have a good source? )</font>
This can be found in the service manual.
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
2000 JOHN DEERE 310E BACKHOE (A62129)
2000 JOHN DEERE...
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
2009 Ford Escape SUV (A61569)
2009 Ford Escape...
