Testing Hydraulic Cylinders
/ Testing Hydraulic Cylinders #1
SouthernConservative
Central Texas
Kubota L4310 4X4 HST w/LA 681 FEL
I have 8 Hydraulic Cylinders from a Loader Bucket, I removed each of the cylinders - there was fliud in each hose and each cylinder the oil was free flowing and clear. I would like to know if there is a way to test the cylinders in order to know if they will extend and retract as they should?
I contacted a local hydraulic shop and they will compression test each one for $65.00 and repair as needed....:eek:
I would like to test them in another fashion as I only need 4 of the 8 to function for the project I am working on...any assistance or ideals would be great.
Thanks,
/ Testing Hydraulic Cylinders #2
I would put hoses and couplers on them and hook them to the remotes on the tractor
/ Testing Hydraulic Cylinders #4
My hydro shop test with compressed air. I believe he uses a oxygen tank that has a 2500 psi rating to simulate hydro pressure. He has told me if it can hold air it will hold hydro fluid.
Chris
Thanks for the advice - I had planned to hook them up one or two at a time when I get the 3rd function set up on my Kubota next week - However I posted the question as the hydraulic repair shop warned against doing so as "trash" from the cylinders could enter the return hose and thus into the main holding tank...and as I am winging with help from TBN members I thought I should ask..
A follow up question -
Should I place an inline fiter on the return side of the cylinders during testing of the cylinders? TSC sells them for $32.00..would this trap any junk that may be in the used cylinders or would I be wasting $40.00?
Thanks again,
/ Testing Hydraulic Cylinders #6
If the fluid you pumped out(by manually cycling the cylinders) was clean and clear like you said, with no signs of debris or water then i would just hook them without worrying about it.
Don't stress over this...it ain't rocket science:D
Kennyd,
Thanks - I teach government and economic finance for a living - so the details are all I stress about.
I will push / pull until the old oil is out of the cylinders and then duct tape the cylinders closed until I can attach them to the tractor for testing.:D
Thanks,
"Robbing peter to pay paul"
Even college level students have a hard time understanding how we - the USA borrow from ourselves - then allow other countries to "buy" the debt and thus cause the USA to owe other countries for our debt.:mad::confused:
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
East Texas Gooseneck Trailer (A65563)
East Texas...
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
Wolverine Quick Attach 84" Snow Pusher (A66285)
Wolverine Quick...
