Testing Hydraulic Cylinders
   / Testing Hydraulic Cylinders #1
SouthernConservative
Bronze Member
Central Texas
Kubota L4310 4X4 HST w/LA 681 FEL
I have 8 Hydraulic Cylinders from a Loader Bucket, I removed each of the cylinders - there was fliud in each hose and each cylinder the oil was free flowing and clear. I would like to know if there is a way to test the cylinders in order to know if they will extend and retract as they should?
I contacted a local hydraulic shop and they will compression test each one for $65.00 and repair as needed....:eek:
I would like to test them in another fashion as I only need 4 of the 8 to function for the project I am working on...any assistance or ideals would be great.
Thanks,
   / Testing Hydraulic Cylinders #2
I would put hoses and couplers on them and hook them to the remotes on the tractor
   / Testing Hydraulic Cylinders #4
My hydro shop test with compressed air. I believe he uses a oxygen tank that has a 2500 psi rating to simulate hydro pressure. He has told me if it can hold air it will hold hydro fluid.
Chris
Thanks for the advice - I had planned to hook them up one or two at a time when I get the 3rd function set up on my Kubota next week - However I posted the question as the hydraulic repair shop warned against doing so as "trash" from the cylinders could enter the return hose and thus into the main holding tank...and as I am winging with help from TBN members I thought I should ask..
A follow up question -
Should I place an inline fiter on the return side of the cylinders during testing of the cylinders? TSC sells them for $32.00..would this trap any junk that may be in the used cylinders or would I be wasting $40.00?
Thanks again,
   / Testing Hydraulic Cylinders #6
If the fluid you pumped out(by manually cycling the cylinders) was clean and clear like you said, with no signs of debris or water then i would just hook them without worrying about it.
Don't stress over this...it ain't rocket science:D
Kennyd,
Thanks - I teach government and economic finance for a living - so the details are all I stress about.
I will push / pull until the old oil is out of the cylinders and then duct tape the cylinders closed until I can attach them to the tractor for testing.:D
Thanks,
   / Testing Hydraulic Cylinders #9
Kennyd,
Thanks,
I gotta ask - How do you describe the national debt?
"Robbing peter to pay paul"
Even college level students have a hard time understanding how we - the USA borrow from ourselves - then allow other countries to "buy" the debt and thus cause the USA to owe other countries for our debt.:mad::confused:
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
