Terramite vs Kubota U15
   / Terramite vs Kubota U15 #31
The Eaton pump has been replaced with a slightly bigger pump. The Modification was done on a T5c, T7 and T9 aswell as the TSS48 and Rollerscreed. For each model we have setup the pressures differently so we get maximum out of the motor. The new pump also allows for you to add an additional hydraulic filter directly onto the transmission. In SA I now run the machines with the new pumps on Hyd 68 Oil.
   / Terramite vs Kubota U15 #32
Very cool. Did you also replace the hydraulic pump for the loader and backhoe? Do you have the model number of new Eaton pump you installed om the T9?
   / Terramite vs Kubota U15 #33
Ill post some pictures and videos later of machines in Africa.
Terramites can take a beating provided they are maintained. I personally watched impossible become possible.
In SA we have replaced the Eaton Pumps to a new pump that makes the machines alot more refined and quicker on the tramming. On the other hand once you pump up the Rev's you then get brute force and aggression.
When you visit SA let me know Il personally take you on a tour of the Terramites around. :)
I would also like to know what you switched the eatons for?
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
