Terramite Attachments, Mods and Assesories
   / Terramite Attachments, Mods and Assesories #1
Terramite T7 - 2007
I've begun a scavenger hunt going through older post for Terramite mods, attachments and assesories...found so far:
Backhoe Thumbs: https://www.tractorbynet.com/forums/showthread.php?t=133147 https://www.tractorbynet.com/forums/showthread.php?t=415206
Bucket Hitch Mount: https://www.tractorbynet.com/forums/showthread.php?t=415206
Backhoe Ripper: https://www.tractorbynet.com/forums/showthread.php?t=376548
Front Loader Quick Release Mod: https://www.tractorbynet.com/forums/showthread.php?t=371050
Thought this would be a good thread to collect mods, attachments and assesory ideas for Terramite...I'll keep updating links above as I find them...
Anyone else made any attachments? Made any cool modifications or assesories for their Terramite?
This is an attachment I made, I'm sure somebody has done this before but it turned out pretty good for my T7... Friend was getting rid of a 36-in mower plow... Removed the bracket but repurposed the blade/spring added a threaded rod to go through the backhoe bucket and bent a thick washer over to match the curve... I originally used the U-shaped skid brackets from the plow to hold onto the bucket teeth but had to switch to piece of shelving bracket due to them bending...
I wanted something for light finish gradding on heavy slopes...I left the spring in the system so if I hit a rock or dig too hard the plow has give...works well...only issue is with the spring I cannot back drag...
(Sorry for the double pictures, for some reason I can not edit/remove the first set)
View attachment 674002View attachment 674003View attachment 674004View attachment 674005View attachment 674006View attachment 674007
   / Terramite Attachments, Mods and Assesories #3
Nice mod. Looks useful.
I've added a Linville thumb (hydraulic) to the backhoe and a tilting skidsteer qa setup to the loader arms. (sstilt is the item from palletforks.com).
To power these I've used the power beyond on the bh valve and a summit thumb switch/solenoid combo to the bh and a joystick type 2 spool valve to the left of the steering wheel for grapple and tilt circuits.
I think I've put pics in other posts. If not I'll add here.
   / Terramite Attachments, Mods and Assesories #4
I would like to see your mods agjones. Can you post some pictures?
   / Terramite Attachments, Mods and Assesories #5
Here are some pictures of the mods on my T6.
Tilt ss plate from titan. Linville industries thumb. Summit solenoid switch kit for handle. 2 spool joystick valve to control front tilt and grapple functions.
Nice work! Was putting on the full hydro thumb worth the extra cost... I was looking at the semi thumb that Linville makes and wondering if that would be good enough... How did you add the extra hydro lines for the thumb and grapple? Did you use diverter valves, third function kit or another method?
   / Terramite Attachments, Mods and Assesories #7
Absolutely worth it. I had a cylinder that I used... So the cost was limited. I split the power beyond flow of the bh valve w a divider the two flows go to the solenoid valve for the thumb and the two spool grapple/tilt. No selection required.
Nice... Any flow rate issues running thumb while articulating backhoe?
   / Terramite Attachments, Mods and Assesories #9
Nope. I'm pretty happy with the way it works.
   / Terramite Attachments, Mods and Assesories #10
T6 extension handle for the foot pedal, reduces foot stress and allows machine to moved while seat is the backhoe position. Counterweight needed to control constant drag on reverse gear, combined to create a pedal extension to reduce foot fatique.pedalextension.jpg
Case W7 Wheel Loader (A55272)
Case W7 Wheel...
2372 (A58376)
2372 (A58376)
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2838 (A58376)
2838 (A58376)
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
