terraman51
/ terraman51 #1
terraman51
Auburn ,Maine
Terramite T5C John Deere 455
Hello All, would like to know if there is a small auxiliary pump that would run the power steering of t5c terramite, 250 to 300 psi ?
/ terraman51
well the main pump "eaton" puts out that kind of pressure, but the section of it that runs the power steering is only 300 psi max.
/ terraman51 #4
Does your hyd steering use the charge pump pressure?
I use an Eaton VSP pump in my Power-Trac, and the charge pump puts out about 350 psi.
/ terraman51 #6
If you have a variable speed pump, you probably have a charge pump.
The charge pump is the only low pressure element associated with a variable speed pump that I know of. The charge pump could be internal or external.
Here is a pic of my charge pump.
M or red arrow
2007 International 4400 S/A Dump Truck (A61573)
2007 International...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
5ft. Wooden Cowboy Statue (A61574)
5ft. Wooden Cowboy...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Transfer tank (A61567)
