Tension Pulley Adjustment on MMM
   / Tension Pulley Adjustment on MMM #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
Last night when I was mowing with my TC21D, and MMM, the belt on top of the MMM came off. It was late so I put the Tractor away for the night. This morning I got to looking at it, and the belt just came off the pulleys. I loosed the Tension Pulley, and put it back on. I also decided to tighten the tension on the belt while I was at it. Now comes my question, what is a good way to make sure the belt is tight enough? Also can you overtighten the belt? I really don't want to buy a new belt any faster then I have to. Also I use a pressure washer to clean the top of the MMM off, will the water make harm the belt? Its the best way to clean the deck that I've found. Thanks in advance.
Kent
   / Tension Pulley Adjustment on MMM #2
Kent, my 914A mmm manual indicates that the belt is adjusted correctly when the spring is 5 9/16" long.
I don't see where using a pressure washer would hurt the belt or the deck.
   / Tension Pulley Adjustment on MMM #3
Normally, there's an amount of defection given (at the longest span of belt between pulleys/idlers). On my Befco mower, it's 1/2"-5/8".
The belts stretch quite a bit over the hours of usage. I'm sure most of us don't pull the belt cover(s) off too often to check the tension.
Reckon it's a good idea to do so twice a season or so.
   / Tension Pulley Adjustment on MMM #4
I believe Mike's answer to be correct. You could verify that in your ops manual, or often there is a decal on the deck itself that gives an adjustment spec.
Thanks Mike, Roy, and Rick. I doublechecked the manual after these posts. You are correct. I guess I missed it the first time. Thanks again
Kent
2014 JCB 930 (A53317)
XCMG CV83PD (A53317)
2015 Mitsubishi Outlander Sport SUV (A56859)
2015 Mitsubishi...
Unifarm CD 210 Mower (A57454)
Unifarm CD 210...
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
Ford 3000 Tractor (A57453)
Ford 3000 Tractor...
