Temperature & Pressure Engine Kill Safety Switches
   / Temperature & Pressure Engine Kill Safety Switches #11
Look for a murphy style switch. I know they make them for low oil pressure.. not sure about the temp.
Another way to do it is to 'T' your oil sender so you can ad another sender. Find one that is grounded with pressure. Use a relay with NO contacts.. or both.. wire power directly to the relay 'hot' side, and then wir ethe relay ground pin to that sender. Wire your power to your fuel solenoid thru the NO contacts on the relay. Install a momentary or toggle bypass switch from the relay ground pin to ground. Hit the bypass to energize the relay and thus your fuel solenoid. Start tractor, and keep thge bypass down untill oil pressure comes up.. when oil is up, you can let go of the bypass switch, as the sender is now providing ground to the relay. When oil pressure goes away, the sender opens, and the fuel solenoid is de-energized.
With a handfull of radio shack parts you should be able to make a water temp shutoff in the same fashion.. perhaps in tanden with the oil shutoff, and using some of the same support components.
Soundguy
   / Temperature & Pressure Engine Kill Safety Switches #12
What you need are Murphy switchgages. They are simple, reliable devices for emergency shutdown. Standard equipment on mechanical diesel and natural gas engines (the kind of engines without electronic fuel injection). They wire into the fuel solenoid to shut off the engine when contact is made and require a manual reset.
Murphy is out of Tulsa, OK and any equipment dealer can get them for you.
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2016 Nissan Versa Sedan (A55853)
2016 Nissan Versa...
Deere 333G (A53317)
Deere 333G (A53317)
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
