Temperature Gauge
/ Temperature Gauge #1
km-ri
My temperature gauge starts midway on the gauge upon power up, prior to actually running. Once started it jumps up to the upper limit in minutes. I suspect a faulty device, not sure if it is sending unit or gauge. Any ideas on how to identify the culprit?
/ Temperature Gauge
Disconnected from sender and gauge arm now stays pegged hot. Connected same scenario. I put around 4 hrs on it today. Dead short? 20190623_204122.jpeg20190623_204100.jpeg
/ Temperature Gauge
Well I disassembled the cluster, readjusted the needles and all was well; for a few days. Gauges are off again. Anyone install a separate temp gauge? I can check fuel with the tried and true dip stick. Cost to purchase new gauge cluster?
Thanks
/ Temperature Gauge #4
Take a look at the ground for the panel. Also the 12VDC.
By "adjusting" how did you adjust?
No ground sends a guuage to full scale, grounded it will read zero or cold or whatever at the low end.
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
BAMA BUILT 7x16 Hybrid Dump Trailer (A68134)
BAMA BUILT 7x16...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
