Temperature gauge JX95
   / Temperature gauge JX95 #1
Bob Hall
JX95 IH
I have a JX95 and my temperature gauge is not functioning. I have power at the sending unit and I have power at the gauge. I tried plugging in a new dash cluster and the gauge did not work on it either. I then put a new sending unit on the plug and put it in water that was at least 180 deg. and it still did not work. I then plugged the new cluster in with the new sending unit and that still did not work. At the back of the gauge there are 3 terminals or studs in a triangular pattern. The center one is ground one side is full voltage and the other is the sending voltage and I have current on both sides. Does anyone have a clue.:confused2:
   / Temperature gauge JX95 #2
If the sending unit has only one wire leading to it, your hot water test is invalid. The sender would need a return ground path added, as the tractor chasis and engine provide a ground path when the components are installed.
I think your sender is bad and you have not tested it properly.
There are 2 wires going to the sending unit and when I performed the standalone test putting it in a cup of hot water there was 2 wires going to the sending unit unless you think that quite possibly the unit still needs to be grounded also. it is a possibility I will check it out.
   / Temperature gauge JX95 #4
Was the sender you removed located in the top middle of the cylinder head, or in the water pump housing?
water pump housing
   / Temperature gauge JX95 #6
water pump housing
That sender provides a signal for the cold start advance mechanism in the injection pump. The temp sender for the instrument panel gauge is a single wire sender screwed into the top center of the cylinder head.
Cool, thank you very much. I was starting to think I was crazy or something. That makes total sense.
KENWORTH  DIGGER TRUCK (A50854)
KENWORTH DIGGER...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
