Temp gauge
/ Temp gauge #2
I had a problem with my MF GC 1715 temperature gauge and it proved to be loose screw where mechanical gauge mated with printed circuit board....
Most gauges are basically a volt meter, try disconnecting wire at sender in block and grounding it out to block if gauge moves problem is sender if gauge does not move trace wire back to gauge to be sure of it integrity before you just replace gauge.... Check all electrical connection for their integrity along the way...
Look for item that will look similar to this, it can be on thermostat housing or on head or engine block... Varies according to engine manufacture....
Dale
/ Temp gauge #3
The temperature probe will frequently be found in the area of the thermostat. That is the location of the hottest water headed back to the radiator.
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2025 VR39 39in Vibratory Roller Skid Steer Attachment (A64553)
2025 VR39 39in...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2022 EZ-GO ELITE...
