temp gauge dissection 1710
   / temp gauge dissection 1710 #1
Kent B
Tallahassee FL
1984 Ford 1710
I successfully took apart my temp gauge without breaking the glass. If I am lucky I will be able to insert a cleaner backing and get it to work properly.
I have seen a post explaining how these electrical gauges work. It seems like the ones that are wired straight to the coolant system would be more desirable. Took many variables in the electrical connections on these OEM types.
I don't know if anyone has tried this before but I thought that I would share the moment. It can be done.
   / temp gauge dissection 1710 #2
Kent, that has to be the worst looking gauge I have ever seen. I would not even attempt to restore it. I would buy another one unless you just like a challenge. Good luck.
I imagine you're right. I have been making a list of items to order from the New Holland dealer (nearest place 50 miles). The temp gauge is on my list but in the mean time I'll tinker with what I've got.
I ordered a standard (universal) temp gauge assembly that didn't fit, likewise the one from TSC didn't fit.
   / temp gauge dissection 1710 #4
Yeah, that gauge is awful, Kent. Toss it.
The good news is that at least your gauge is modular. Many newer tractors have the
gauge built into the gauge cluster.
These units are not precise at all, and operate (usually) off a bimetal strip with a coil
of wire around it. The sending unit controls, roughly, how much current goes thru the
coil. I would keep looking for a used or new unit off another vehicle, or another generic
meter from a store, or off eBay.
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Hotsy Pressure Washer (A51573)
Hotsy Pressure...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
