Temp/fuel gauge jump around jd 2155
   / Temp/fuel gauge jump around jd 2155 #1
stevens311
macclesfield,nc
l4200
My 1987 jd 2155 is having problems with the temp and fuel gauges twitching. The temp gauge after a few minutes shows overheating but when I checked the temp not even close to overheating. I replaced temprature sensor and thermostat but still no fix. When the gauges twitch the tachometer twitches too. I have checked all connections and cleaned firewall connection too. Any help would be great. Seems to be electrical but I sure can't find it.
   / Temp/fuel gauge jump around jd 2155 #2
When I purchased my 5210 years ago, the temp gauge was jumping around. I cleaned up the negative cable end where it connects to the tractor as well tractor location, the bolt and the screw hole the bolt went into and the problem went away.
   / Temp/fuel gauge jump around jd 2155 #3
Sounds like a bad ground, "usually" these three are all connected by the same "ground",
check around your dash console, for grounds to frame etc. A schematic would help find the ground wire.
   / Temp/fuel gauge jump around jd 2155 #4
I agree bad ground connection especially dash cluster.
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
INSPECTION (A51573)
INSPECTION (A51573)
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
Case 580D (A47384)
Case 580D (A47384)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
