Temp/fuel gauge jump around jd 2155
   / Temp/fuel gauge jump around jd 2155 #1
stevens311
macclesfield,nc
l4200
My 1987 jd 2155 is having problems with the temp and fuel gauges twitching. The temp gauge after a few minutes shows overheating but when I checked the temp not even close to overheating. I replaced temprature sensor and thermostat but still no fix. When the gauges twitch the tachometer twitches too. I have checked all connections and cleaned firewall connection too. Any help would be great. Seems to be electrical but I sure can't find it.
   / Temp/fuel gauge jump around jd 2155 #2
When I purchased my 5210 years ago, the temp gauge was jumping around. I cleaned up the negative cable end where it connects to the tractor as well tractor location, the bolt and the screw hole the bolt went into and the problem went away.
   / Temp/fuel gauge jump around jd 2155 #3
Sounds like a bad ground, "usually" these three are all connected by the same "ground",
check around your dash console, for grounds to frame etc. A schematic would help find the ground wire.
   / Temp/fuel gauge jump around jd 2155 #4
I agree bad ground connection especially dash cluster.
DOOSAN G90 GENERATOR (A50854)
DOOSAN G90...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
