Tell Me to Change My Oil?
   / Tell Me to Change My Oil? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
2005 Kioti CK30HST.
Changed engine oil with the older Rotella Synth 5-40 at 42 hrs June '06. Oil looks/smells new. Now at 105 hrs.
I am somewhat of an oil fanatic but somehow I don't want to change it.
Tell me I should?!...
Mike
   / Tell Me to Change My Oil? #3
mrutkaus said:
2005 Kioti CK30HST.
Mike
Dont. Youre too far away for me to come get it.
larry
   / Tell Me to Change My Oil? #5
According to my math you have 63 hours on that oil. My owners manual states oil changes every 200 hours. I generally change at 75 hours with the regular Shell Rotella. In normal use I fail to see any reason not to go 150 hours on the Shell Rotella Synthetic. In this case the time factor starts to come into play, I would probably go ahead and change it.
I changed it, I knew I should, but needed encouragement.
2 yrs.
Used same synth 5-40 rotella with a little moly.
Mike
   / Tell Me to Change My Oil? #7
mrutkaus said:
2005 Kioti CK30HST.
Mike
Going by oil color is, um, worthless; unless you are superman.
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
UNUSED FUTURE BD43 HYD BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BD43...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
