Tell me more about remotes
   / Tell me more about remotes #1
Zachary
without sounding too idiotic, what are remotes and what do they do? and Why do I need at least 2 for a L3130 I'm planning to buy? thanks ahead of time...
   / Tell me more about remotes #2
Remotes are additional access points to your tractor's hydraulic system. Generally CUTs come without remotes (larger more expensive CUTs usually have at least one however). The main reason to have remotes is to run implements that require hydraulic power. Basic implements like a plow, box blade or bush hog do not require any remotes as they just operate from the 3PT hitch and (for a bush hog) the tractor PTO. However, if you wanted to get optimal use of a box blade, rake, rear blade etc you could install a top and tilt setup that would allow you to make adjustments to the top link length without stopping and getting off your tractor. Same is true of the ability to use a blade or box blade at an angle to crown a road. You can set that manually with the 3PT arms but using a hydraulic tilt function (run by a remote valve), you can do that from your seat.
You can install remotes singlely or in pairs. I have, for example, only one set of rear remotes on my tractor. That means I could run a hydraulic top link but not that plus the tilt function at the same time. If I installed another set I could do both. How many you need depends on what you intend to use them for but I think most folks would agree that two is a good number to have.
Remotes cost $$ and while the exact amount depends on your tractor and who installs it, it seems that $400-500 per remote is a minimum cost with some dealers getting a few hundred more per pair. (note: there is potential confusion regarding the numbers of remotes as each single remote actually has two lines, one for hydraulic fluid output and the other is a return. A pair of remotes therefore actually has 4 lines and connectors.) Each remote can operate one function though that can vary from something as simple as the toplink length to a complex tool such as a backhoe.
There are some hydraulic mavens on TBN who can clarify technical aspects of remotes further but the bottom line is that if you are going to do more than just hook up a mower to your 3PT hitch, then eventually you will want at least one and probably a pair of remotes.
   / Tell me more about remotes #3
A pair of remotes (two functions) should be a minimum for anyone. This allows you to have a hydraulic top link, which is probably the most useful attachment you will ever get, plus another attachment like a tilt link or a hydraulic dump wagon.
Factory remotes are expensive but nicely integrated into the operator platform. Stand-alone aux valves are 50-75% cheaper but require mounting somewhere either on the ROPS or on the fender.
There have been literally hundreds of posts here on "rear remotes". Just do a search and you will find enough reading material to last you for a few days.
   / Tell me more about remotes #4
Zachary;
I have a dealer installed BH90 on my 3130. I have a supply and return line for the Back hoe. I think this is called "power beyond". These must be connected together when the BH is off the tractor. No big deal. I was considering a 3-point hitch log splitter. I guess I could connect the splitter to the supply and return. When the bh is connected my 3-point hitch will not operate. I assume if the spiltter is attached I will not be able to raise and lower it without reconnecting the lines. The dealer quoted me around $800.00 to install a rear remote. I bought a stand alone splitter instead. Get as much as you can when you buy the tractor. You may have more leverage??
RPK
2013 FORD F150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F150 XL...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
Hose Reel (A55758)
Hose Reel (A55758)
John Deere utv cart (A55787)
John Deere utv...
2025 GGMA GM670 Compact Track Loader Skid Steer (A55787)
2025 GGMA GM670...
