3-Point Hitch Telescoping Stabilizers
   / Telescoping Stabilizers #32
He has about a four week backlog. Got my order in his list last week
   / Telescoping Stabilizers #34
$180 including shipping
   / Telescoping Stabilizers #35
Thanks......this is probably my next purchase.......I bought the Bxpanded hooks for the FEL bucket.....and just ordered the toolbox from them that mounts to the ROPS
   / Telescoping Stabilizers #36
You can get them directly from Kubota for the L3200/L3800/L3301/L3901 and similar sized tractor. Part # L8430. They were $175 when I bought them. Also available for B models, but I don't have that part #.
   / Telescoping Stabilizers #37
Bought a pair for my BX22...they make installing 3PH implements much easier. At first I was concerned that not having turnbuckles to snug things up would be an issue, but that hasn't been the case. Just don't forget to install the pins before using your implement like I once did...nothing bad happened during a full day of work and it was a chipper!
   / Telescoping Stabilizers #38
I haven't seen one I like and they all set the equipment back some distance.
Worse yet, the one I bought (prematurely) has compatibility issues and won't work with many things I try to mount back there. For starters, the distance between left and right pin locations is hard fixed in the quick-attach adapters and every time I turn around an attachment is too wide or has some other issue. Sorry I bought it.
   / Telescoping Stabilizers #39
Half my gear (usually old craigslist cheap finds) wasn't quick hitch compatible. My welder & plasma cutter quickly remedied that. Sooo worth it to not have to get off the tractor to hitch up.
The day I picked up my tractor, rotary cutter & back blade from the dealer I watched them fight for 10 minutes to get the rotary hitched up. I didn't take it off until my quick hitch came in. Never spent half as long as the dealer did hitching up anything with my quick hitch.
Most new gear is quick hitch compatible. Its usually old stuff you have to worry about.
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
1991 International 4900 Box Truck (A55315)
1991 International...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
UNUSED JCT HYD TRENCHER (A57193)
UNUSED JCT HYD...
