3-Point Hitch Telescoping draft links
/ Telescoping draft links #21
Yeah, I think the bending problem is being caused by turning without first raising the implement, and also backing up without first raising the implement. Too much torque on the stabilizers
/ Telescoping draft links #22
I had these made up after I bent and broke a telescoping link twice.
/ Telescoping draft links #25
Just broke the "solid" part(cast) of one of the telescoping links yesterday while boxing. Is this a stealer part or can I get it at tractor supply or?
I can't believe the system is designed to lift the implement whenever backing or turning. I think the excessive torque comes from the implement slapping from side to side because of it's loose design. Once again I never had a problem with the turnbuckle type. I kept them tight and the implement followed the tractor with no problem. When I mow with these new types, and I back up the implement does a serpentine before it settles down and goes straight.
Not sure which part you are talking about. I broke the part that attaches it to the tractor and my dealer had to weld a new part on. H replaced the other side as a precaution and you could see the wear from it hitting as it moved.
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
