teflon tape
/ teflon tape #1
wedge40
I hope this is the right area. I was making up some new air hoses so I could use my 3/4" ratchet to tighten the nuts on my bushog blades.
How in the heck to you get rid of the static electricity on the tape. It's a real pain to handle when it keeps wanting to pull toward your finger and not around the threads.
Is there some sort of trick, or do I just deal with it?
Wedge
/ teflon tape #2
Everyone has their own trick, mine is to hold the tape spool in my left hand (like a tape dispenser with my ring finger thru the tape spool center) with a bit of tape sticking out, and the threaded fitting, hose, pipe etc in the right hand, then turn the threads clockwise just like you would screw it in, winding a couple of turns of tape onto/into the threads. This allows holding the proper tension and winding on the tape in the proper direction.
/ teflon tape #3
I think the right way is what works best for you. Myself I always hold the fitting in my left hand. I then hold the end of the tape with my thumb then I turn about three wraps of tape around the treads as if you were tightening a fitting on them.
/ teflon tape #4
The Heavier, Mil Spec., Teflon Tape isn't as susceptible to Static.
I've have it in Yellow for Gas Pipe and Pink for Water and Air...
/ teflon tape #5
be careful using teflon tape that you dont over tighten it and split the nut i use pulmbers paste so as to not split the brass its like never sieze but made for water connections wonderful stuff and no hassels with static elictricty
SPARTAN XBC173072-72" HYD BRUSH CUTTER (A65056)
SPARTAN...
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
2019 Harley-Davidson FLHTP Electra Glide Motorcycle (A66738)
2019...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
IRANCH WOOD GRAB ATTACHMENT (A67714)
IRANCH WOOD GRAB...
