ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,735
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
You shouldn’t have to use any kind of sealant if you are connecting them properly.
That is true of most types of fittings used for hydraulics but not NPT.
NPT fittings seal by deforming the threads. Most other fittings used for hydraulics seal with O rings or dedicated sealing surfaces like the tapered seal on JIC fittings. NPT was designed for low pressure stuff like home water systems, under 100 psi. In order to get NPT fittings to seal under tractor hydraulic system pressures (2400 psi or so), I find they need sealant. Teflon dope is a lubricant but not much of a sealant and does not work in my experience. Teflon tape can seal but it can also get dislodged, go into the hydraulic system and plug passages. Loctite 545 which is are made specifically for sealing hydraulic system NPT threads has worked the best for me.
