Tef head off woth first parts fatality
   / Tef head off woth first parts fatality #1
Mick Oz
Townsville Queensland
Ferguson TED20 TEF20 DongFeng ZB25
I finally got the time to actually start removing the head from my 1956 Tef.
When I removed the tappet/rocker assembly, My first parts fatality occurred.
One of the towers holding the rocker shaft in place has broken into 3 parts.
Firstly what would you call this part and do you know if it is available to purchase, or do I learn to weld cast iron?
   / Tef head off woth first parts fatality #2
Hmm, strange failure, a used one should be quite easy to get.
   / Tef head off woth first parts fatality #3
AGCO Parts Books ->
guest view ->
select massey ferguson from drop down menu ->
type in TE 20 ->
click search ->
all the way down at the bottom i do believe is link you want.
from there just google the part numbers.
you also might try googling, tractor salvage yards, or a local agco dealer (and there many brands), and see if they can pull something up.
The other question I have is about the rings that are above the liner.
I can see that the top incomplete ring creates the precombustion chamber. But I have a second complete ring below the top one.
Is this average or do I have a non standard cylinder liner set?
Sorry, pictures.
Thank you Boggen
Unfortunately the site will not allow a guest login from my Ipad. But I will keep looking.
   / Tef head off woth first parts fatality #8
I do belive there are two rings, if I understand my original service manual
Two rings would be good, an engine from 1956 can be hard enough to find parts for without it being an unusual version
   / Tef head off woth first parts fatality #10
Agreed. The only TEF I ever saw has a Standard Diesel in it. Happily, I didn't need engine parts.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2025 AGT SSFM81 Hydraulic Drum Mulcher Skid Steer Attachment (A50322)
2025 AGT SSFM81...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2024 Victor X-PRO Mini Dirt Bike (A50324)
2024 Victor X-PRO...
377669 (A51573)
377669 (A51573)
2012 Vicon Andex 423T (A50120)
2012 Vicon Andex...
