Tecumseh 7HP Snowblower carb problem
   / Tecumseh 7HP Snowblower carb problem #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi All,
I've been having difficulty with a carb on a Tecumseh 7HP snowblower engine, model HSK70 on a Simplicity blower. I bought a new carb and it ran very nicely until I put the metal cover back and then it ran poorly, mainly revved higher. Difficult to adjust once cover is on except for the main jet on the bowl bottom. Suggestions? Thanks!
   / Tecumseh 7HP Snowblower carb problem #2
The cover shouldn't make a difference. Some covers have a hole inline with the low mixture screw for adjusting. Does it run better without the cover on you say ?
Almost sounds like you have a wrong screw in place somewhere. Only wild guesses. Or your cover is sitting somehow to close to carb opening causing it change with cover installed.
Hi,
Thanks for your reply. I agree the cover shouldn't make a difference. I've worked on many of these snowblower engines, and none has ever done this. No screws out of place that I know of, just a dome scratcher!
   / Tecumseh 7HP Snowblower carb problem #5
By runs better is it idling down, flooding out , surging etc?
   / Tecumseh 7HP Snowblower carb problem #6
Without any photos to see the issue, I would guess that, 1 - the heat cover is blocking the carb intake.
2. The heat cover is interfering with the governor.
Richard
Hi Richard,
Thanks for your reply. Hmm, both things worth checking. The guard that is in front of the carb intake spaces the cover from the intake, so don't believe it's coming from there. As to the governor being interfered with, that's a possibility worth checking. Without the cover, I can adjust the carb, although it does surge when the governor screw in turned in. RPM at best setting is about 3100 or so. It's finiky at best, but does run OK without the cover. When I go to put the cover on, I don't even have to put the two carb intake screws on, just get the cover near the intake and it begins to accelerate and won't adjust no matter the position of the throttle control. I welcome your thoughts...
   / Tecumseh 7HP Snowblower carb problem #8
Can you post some photos of the carb and the governor area ?
Hi Richard,
Here are a few pics of my blower. I'll be interested to see what you think.
   / Tecumseh 7HP Snowblower carb problem #10
Photo #4 shows the float blow vent tube being kinked right at the exit of the carb. You need to change this. Where does the other end of the vent tube go ?
On Photo #7, on the left side of the cover, what does the part that has the sheet metal screw sticking thru it do ?
Can you show photo of the shield installed and look to see if the shield is interfering with the governor arm in that area.
Is this carb an exact replacement part ? For example, did the throttle linkage fit without any bending of the linkage ?
2021 KOMATSU PC88MR-10 EXCAVATOR (A52709)
2021 KOMATSU...
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
CAT 336E (A58214)
CAT 336E (A58214)
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
