TEA 20 Hydraulic issues
   / TEA 20 Hydraulic issues #1
johnskoren
Tea 20 Massey Ferguson
Hi John I am having troubles with a Massey TEA 20 Hydraulic system failure. I remove the lift cover cleaned out the oil and sludge put it back together and had it lifting but not dropping what th could be the problem
   / TEA 20 Hydraulic issues #2
Hi John and welcome
It sounds like something on the linkage control valve is not right might want to pull the top again and see if everything is in place, also check control spool is moving correctly
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
