TD75 4WD Hydraulic Problem
   / TD75 4WD Hydraulic Problem #1
lowellcantrell
West Liberty, KY
Kubota 6800 4WD
Any NH owners had trouble with hydraulics "locking up" to the point that the loader, remotes, nor lift arms will not move? Neighbor has a TN75 4WD that locks up from time to time. Has to remove pump plug, start engine, rotate sterling wheel to bleed, then replace plug. Has to do this seven to eight times each summer. Any ideas what might be the problem?
   / TD75 4WD Hydraulic Problem #2
My first suggestion would be to make sure the hydraulic filter is screwed on tight. Second thought is to check the condition of the coupling hose on the suction tube at the filter base, and if they are still there, replace the chickensquat factory hose clamps with something more modern that can be tightened. Air leaks in this area can cause the pumps to have difficulty picking up prime when the tractor is not used for extended periods of time.
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
20711 (A50323)
20711 (A50323)
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
