TD5030 4WD Not Disengaging
   / TD5030 4WD Not Disengaging #1
kf4uda
Middle TN
NH TD5030, 861 Ford Powermaster, CaseIH Farmall 35A, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
Well, I finally have a problem with my TD5030. The 4WD is not disengaging when I move the control rod to the 2WD position. I have tried moving the tractor forward and reverse direction, still no release. I crawled under the tractor and checked out the linkage. I was hoping to find a missing pin or key for an easy fix but no luck. Anybody have any ideas? Tractor has 12x12 mechanical transmission.
I guess that I should post a follow-up in case someone else has this problem. I figured out that when it does not come out of 4wd I can push down on the control rod while easing out on the clutch (with reverse selected) and the control rod will move down a little farther and release. Most of the time it works the way it is suppose to.
   / TD5030 4WD Not Disengaging #3
Lots of us have to move the machine a bit, or reverse it, to disengage 4wd. No biggie.
Jim
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
DEWALT 20V ELECTRIC WEEDEATER (A51248)
DEWALT 20V...
2021 Triple Crown U6X14T 14ft T/A Flatbed Trailer (A51694)
2021 Triple Crown...
WORKSAVER RMB-325-PW LOT IDENTIFIER 52 (A53084)
WORKSAVER...
2012 VANGUARD 53FT DRY VAN TRAILER (A53426)
2012 VANGUARD 53FT...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
