TD5030 4WD Not Disengaging
   / TD5030 4WD Not Disengaging #1
kf4uda
Veteran Member
Middle TN
NH TD5030, 861 Ford Powermaster, CaseIH Farmall 35A, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
Well, I finally have a problem with my TD5030. The 4WD is not disengaging when I move the control rod to the 2WD position. I have tried moving the tractor forward and reverse direction, still no release. I crawled under the tractor and checked out the linkage. I was hoping to find a missing pin or key for an easy fix but no luck. Anybody have any ideas? Tractor has 12x12 mechanical transmission.
I guess that I should post a follow-up in case someone else has this problem. I figured out that when it does not come out of 4wd I can push down on the control rod while easing out on the clutch (with reverse selected) and the control rod will move down a little farther and release. Most of the time it works the way it is suppose to.
   / TD5030 4WD Not Disengaging #3
Lots of us have to move the machine a bit, or reverse it, to disengage 4wd. No biggie.
Jim
HARDEE RD72M LOT NUMBER 269 (A53084)
HARDEE RD72M LOT...
UNUSED RAYTREE RMBG72-72" ROOT GRAPPLE (A51248)
UNUSED RAYTREE...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
