TD35 FWD Will Not Disengage
   / TD35 FWD Will Not Disengage #1
msdougherty
Culpeper, VA
New Holland TC35DA
I have a TD35 in FWD, but cannot get it to disengage. I've tried to engage either of the hydrostatic drive pedals, but am still unable to move the FWD lever out of the engaged position. Any ideas what to try next?
   / TD35 FWD Will Not Disengage #2
Do you have a loader? If so, use the loader to raise the front wheels off the ground and it should come out of 4wd easily. It's common to have driveline windup when 4wd is engaged. It's like the driveshaft becomes a wound up spring. That's due to the front tires rolling at slightly different speeds than the rears or turning while in 4wd. Some people are able to get the windup out by turning hard from side to side while backing slowly, but lifting the front end with the loader works every time. This is nothing wrong with your tractor. All 4wd tractors with manual shift have the same problem as does my Kawasaki 4wd Mule. It's frustrating, but normal.
Thanks, Jinman. Worked like a champ! I never would have thought to do that.
   / TD35 FWD Will Not Disengage #4
That is exactly how I get my TC35A out of FWD. I use the loader and pop the front wheels off the ground as I disengage. I do it so automatically that I don't even think about it. It is second nature by now.
   / TD35 FWD Will Not Disengage #5
It also helps if the front wheels are straight.
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
