TC55DA cuts out while driving
   / TC55DA cuts out while driving #1
devildog26
Michigan
I have a brand new TC55DA with 10 hours on it.. I had a sprayer on the back and had the RPM up to about 2000 and as I drove and sprayed the tractor would just start to loose power and die. If I slowed down and put it in neutral I could recover it before it died but it would not rev up for a little bit and just chugged. I tried that with the PTO on and off and it still did it either way. But if I got off the tractor and turned the RPM up real high for the PTO and let it run it did not stall only when I was driving.. Does anyone have any ideas?
Thanks,
Bill
Thanks,
Bill
   / TC55DA cuts out while driving #3
Sounds like a fuel filter is plugged with water or dirt or debris. Remove filter and clean. then see if that cures problem. You may have gotten some bad fuel.
   / TC55DA cuts out while driving #4
   / TC55DA cuts out while driving #5
While you're spun around could you be lifting part of your weight off the seat? I had a case while snow blowing where my engine was cutting out and made a determination that that's what was happening in my case. Sometimes I wonder if it would be a good idea to just bypass the seat switch.
   / TC55DA cuts out while driving #6
Thanks for all the help.. I will look at the fuel filter and also pay attention and see if it is the way i am sitting on the seat. I will let you know what i find out...
Thanks again.
Thanks again.
   / TC55DA cuts out while driving #9
When my Nh 7610s did that it was fuel starvation..
Check water traps and filters.. check fuel level.. and flow from tap.. might be a plugged tank tap screen ( mine was ).. bleed lines and try her out.
Soundguy
   / TC55DA cuts out while driving #10
Soundguy
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
WESSEX CHT-100R-E LOT NUMBER 237 (A53084)
WESSEX CHT-100R-E...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
