Oil & Fuel TC55 "real" fuel capacity
   / TC55 "real" fuel capacity
lug nut said:
I ran mine a little too long when I first brought it home. It had been on the "empty" mark for probably an hour or more. When I took the cap off to fill it up, I could see the bottom of the fuel tank. It was almost completely out. It took nearly 13 gallons to fill it up.:eek:
OK - with that my curiousity is now satisfied :) ....
thanks
~paul
   / TC55 "real" fuel capacity #12
I ran mine down low once and the gauge didnt respond to movement it took 12 gal to fill it up. Most of the time i havn't put over 8 or 9 gal in it at any one time.
   / TC55 "real" fuel capacity #13
i ran my tc33d out of fuel a few times and i just shut it off quick when she starts to run out and after i fill it up she starts up everytime without bleeding. It sputters for a few seconds but it takes off. Just get it off quick!!
mike
   / TC55 "real" fuel capacity #14
The newer ones with electric charge pumps aren't bad. On my 7610s, you just turn a thumb screw with the key on till fuel bubbles, then tightent he screw.. and you are good to go... On my older 5000.. you gotta sometimes get the wrenches out to bleed the lines.. and the battery charger too.. if it feels like being stubborn..
Soundguy
   / TC55 "real" fuel capacity #15
i ran mine the other day down past the empty below the marks completely and it took about 10 gallons. I thought i was on fumes it was so low. I got 100 hours on it now.
Mike
Mike
yup - that's what I've seen....kinda forces you to temp fate :eek:
~paul
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
2013 Wanco WTSP Folding Solar S/A Towable Arrow Board (A55973)
2013 Wanco WTSP...
2015 Freightliner Cascadia SLEEPER (A58017)
2015 Freightliner...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
