TC55 hydro??
   / TC55 hydro?? #1
froggy
Cooke County, Texas
JD4320 with TNT, electric diverter, cruise control and air suspension seat.
Now that John Deere has the 4720 hydro, was wondering if anyone thought whether New Holland would make a hydro for the TC55 in the near future?
   / TC55 hydro?? #2
Doubt it. The hydros main advantage is while mowing lawns. The TC 55 is designed more for the small farm/ large acreage guy who just wants to run slightly larger equipment. No real need to invest millions to design a hydro for it.
   / TC55 hydro?? #3
Froggy, I think the TC55 with hydro is unlikely because of the size, pressures, and temperature required to operate with the higher power of the TC55.
The Class III tractors already run at 5000 psi maximum pressure. To keep pressures under control, you could increase the size of the hydraulic motor, but then you have to have a much larger physical space to put it into. You also have to keep it cool and that's no small problem to solve either.
I think the TC55 is larger than any of the JDs you mentioned. I'm not sure about JD, but the hydro transmission on the NH TC35DA has no less power output than the one on the TC40/45DAs. They all have the identical relief pressure, so the 40 and 45 just waste power a lot of the time.
I wish there was actually a hybrid transmission that could provide hydro like controls for low torque applications like mowing and other primary PTO functions. When doing draft work, that transmission would change to gear mode and be driven directly. As long as I'm dreaming, I figure I might as well dream big. /forums/images/graemlins/smile.gif
   / TC55 hydro??
Jim,
Anything will be an improvement over the 40 yr. old non-synchronized gear tractor that I have now. Will probably have to settle for the electro-hydraulic shuttle on the TC55 or the hydrostatic on the TC45 when I buy one in two years. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Doyle
   / TC55 hydro?? #5
The TC55 is just an updated, higher powered version of the 2120 shich was one of Ford / New Holland's most popular models. I have used my 2120 with hydraulic shuttle for 17 years and don't find it at all hard to use. It is not at all like the mechanical transmissions you may be thinking of.
Andy
   / TC55 hydro??
Andy,
I think my attempt at humor failed.
/forums/images/graemlins/smirk.gif
Doyle
   / TC55 hydro?? #7
</font><font color="blue" class="small">( I think my attempt at humor failed. )</font>
Doyle, since we are having fun, let me "poke" a little fun at New Holland by asking if you or anyone else has heard of someone buying a TC48? What were they thinking? Would anyone buy the TC48 instead of going up to the TC55 if you wanted a gear tractor? I am really baffled at why NH placed these two model tractors into their lineup. /forums/images/graemlins/smile.gif
Okay, end of rant....
/forums/images/graemlins/laugh.gif
   / TC55 hydro?? #8
<font color="blue">I am really baffled at why NH placed these two model tractors into their lineup. </font>
Isn't the 48 a non turbo machine? Some buyers might not like a turbo. Increased maint? Shorter life?
Food for thought
   / TC55 hydro?? #9
Strange as it may sound some customers do not like the hydraulic shuttle shift. So they opt for the manual shuttle of the TC48.
   / TC55 hydro??
Turbo aside, they can get the manual synchro-shuttle in the TC55, too. For approximately $1,200 - $1,300 more they also get 7 seven more horsepower.
Aluminum Boat Top (A53117)
Aluminum Boat Top...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
MCDON D60 HARVEST HEADER (A51247)
MCDON D60 HARVEST...
JOHN DEERE CP 770 LOT IDENTIFIER 191 (A53084)
JOHN DEERE CP 770...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2022 KMC 21-37-HD LOT IDENTIFIER 150 (A53084)
2022 KMC 21-37-HD...
