TC55 EHSS Shuttle lever adjustment?
   / TC55 EHSS Shuttle lever adjustment? #1
jjbath
Northwest New Jersey
TC35
Is there and adjustment for the Shuttle lever on the TC55? I have been noticing lately that when I shift into reverse it doesn't always engage. I need to give an extra tug on the lever for it to go. Forward seems to be fine and reverse seems fine once engaged.
I have been searching and I can't find anything. There is nothing in the owners manual either.
Thanks in advance.
Jeff
I guess I'll have to call the dealer.
I finally figured out what this was. I as going to by a new swtich but when I found out it was almost $400 I decided to do some troubleshooting. I found that the nut (#4 in the picture below) was loose allowing the switch (#3) to rotate and sometimes the switch didn't actually engage.
The nut is actually plastic and its round not hexagonal as the image shows.
Hopefully this will help someone else with a similar issue.
   / TC55 EHSS Shuttle lever adjustment? #4
Funny, I never had that problem in the 9 years I owned mine.
According to my dealer there I an update kit for the switch. It look like it was replaced at some point. Maybe that retainer nut wasn't tightened properly. I'm just happy it was something simple. That switch is almost $400.
   / TC55 EHSS Shuttle lever adjustment? #6
how many hours on the tractor?
That was 1010 on it when I bought it. Now it has 1090.
Anyone have a the tech manual on replacing the inching cable? It looks pretty straightforward but you can never be too careful.
   / TC55 EHSS Shuttle lever adjustment? #9
I just traded my TC55DA for a T4.75 Powerstar yesterday.
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
